What body size do i need
I have a Bergonzoni that is 8 years old and i need a body. So how do i measure correctly. The guy says its a long body but when i measure from wheel nut to wheel nut its 521mm or so. and a long body is 535mm. I just dont want to order the wrong body. and info would help
Thats a good question. I have no idea what model it is.. it has the boss motor and when i measure it was 20 1/5 inches from middle of axle to other middle of axel...which turns out to be 520.7mm
Suspended
ok, then i would say the 535mm body is what you want. i think the small ones are 485mm. the 535 will allow for a bit of adjustment. just be sure to get the body centered over both front and back wheels before you punch your body mount holes.
post a couple pics of it, perticularly the front end setup (suspension/shocks, radio plate area and rear end. i can prolly tell you what it is.
I'll see if I can load some pics. Does anyone offer a 2 speed tranny for this car. If so that would be great. I can't find any info. Thanks timmmah
