1/5 tires
Old 07-14-2010, 05:57 PM
Default 1/5 tires
Hi, I 'm trying to locate some 1/5 scale tires for a guy at work that will be used for a 1/5 scale 54 porche. They are like the ones one would see on a VW.
Can anyone give me some leads?
Duck
nitro duck is offline
Old 07-15-2010, 05:13 PM
Suspended
Trader Rating: 16 (100%+)
do you want Tires? or are you looking for Rims as well?
Timmahh is offline
Old 07-15-2010, 05:31 PM
Default tires
He's looking for both.
Duck
Old 07-16-2010, 08:19 AM
Suspended
ok, and are the rims a square drive rim? or are they for a hex drive like on the Bajas?
this may be a trick. i dont ever recall seeing VW type rims (big rounded VW center hub or Rim) look to them.
the best option may be to use HPI Front Rims with the HPI 5T Front Tires (they have a very realistic tread look to them) and have the center VW hubs modded to them.
the 5T rims utilize a 24mm Hex drive, and they make adapters for the square drive rigs to convert to Hex drives for the other wheels.
Timmahh is offline
Old 07-16-2010, 04:47 PM
Default tires
Thanks for your help.
Is there a site where we can check them out?
Duck
Old 07-17-2010, 07:15 AM
CARD's Avatar
Originally Posted by Timmahh
....they make adapters for the square drive rigs to convert to Hex drives for the other wheels.
Huh?! Where can I get that?! Need that desperately...
CARD is offline
Old 07-17-2010, 07:48 AM
Suspended
FG/Harm/Lauterbacher Square drive to HPI HexDrive adapters
all 4
RamTech adapters
http://www.davesmotors.com/s.nl/c.88...t.A/id.5164/.f
AMS adapters
http://www.davesmotors.com/s.nl/c.88...t.A/id.2865/.f
HPI front OUTLAW Rims
http://www.davesmotors.com/s.nl/c.88...t.A/id.5365/.f
you can install these and make some type of VW down hubcap for them.
HPI Desert Radial front tires
http://www.davesmotors.com/s.nl/c.88...t.A/id.5367/.f
you ll need foams and bead locks as well
Front Molded Foams
http://www.davesmotors.com/s.nl/c.88...t.A/id.5375/.f
inner beadlock rings
http://www.davesmotors.com/s.nl/c.88...t.A/id.5754/.f
outer beadlock rings
http://www.davesmotors.com/s.nl/c.88...t.A/id.6478/.f
and a different rim from Silverback RC
http://www.davesmotors.com/s.nl/c.88...t.A/id.7429/.f
these would look good on a VW without the VW Center Hub i think
Timmahh is offline
