Go Back   R/C Tech Forums > General Forums > Oval, Larger Scales and More
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 10-18-2009, 07:45 PM   #1
Default NOVA RUNNING BACKWARDS
I GOT AN OFNA LATEMODEL WITH A NOVA BF21 ON IT AND EVERY TIME I GO AND TRY TO START THE THING IT WANTS TO RUN BACKWARDS AND WE HAVE TRIED ALL KINDS OF THINGS AND IT STILL DOES IT. IF ANYONE CAN HELP ME JUST LET ME KNOW :
grubby is offline   Reply With Quote
Old 10-18-2009, 10:13 PM   #2
Jack Smash's Avatar
Not quite sure how you get an engine to run backwards as your starting method (box, pullstart, rotostart) would automatically get it going in the proper direction. It would have to start and then stop and go the opposite way. Are you sure it is spinning the correct direction when you try to start it, and if it is are you sure your diffs arent in backwards?
http://www.ckrccrawlers.com
<Hot Bodies> <Silva Concepts><Team Tekin>
Jack Smash is offline   Reply With Quote
Old 10-18-2009, 10:38 PM   #3
wingracer's Avatar
Sounds like backward diffs.
Sean. Certified speed crazed mowron.
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 10-19-2009, 03:22 AM   #4
everything is setup right, ive checked a lot of things but it will start up and the tires will be running backwards and then see will die or i willl shut it of and try again and it will keep doing it over and over and over and it will start going in the right direction when it takes a notion to, it got everybody at the track bumfuzzled
Old 10-19-2009, 08:11 PM   #5
It's very possible. I had a XTM .15 engine do this some years back. I don't know exactly how or why it happened but it was rather interesting and it had nothing to do with how the car itself was setup.
Twisted_Metal is offline   Reply With Quote
Old 10-19-2009, 08:26 PM   #6
IVE CHANGED THE FLYWHEEL, CLUTCH SHOES AND SPRINGS AND CLUTCH BELL AND BEARINGS AND IT STILL DOES IT.
Old 10-19-2009, 09:48 PM   #7
pyromania's Avatar
its your starter box. You either have it wired backwards or plugged in backwards
Team Losi 8ight 2.0/ Orion .21 ABI
Losi Strike
M11 w/ Spektrum Module
"Team Terribles"
pyromania is offline   Reply With Quote
Old 10-20-2009, 05:16 AM   #8
THOUGHT THAT TO AND ITS NOT, I EVEN START A BUGGY THAT A I RACE AND IT STARS UP FINE EVERY TIME
Old 10-20-2009, 07:42 AM   #9
bgbelden's Avatar
I would check your diff's. It's happened to me.
BATTLEFIELD RC
Team Terribles TN State Rep
bgbelden is offline   Reply With Quote
Old 10-20-2009, 03:12 PM   #10
CHECKED THAT AND ITS NOT BESIDES AFTER IT FINALY TAKES A NOTION TO IT WILL START GOING FOWARD AND RUN GREAT
Old 10-22-2009, 07:58 AM   #11
Your engine is kicking-back and starting backwards, this happens when your
engine is to rich and/or when you are spinning it to start and does not fire, which it then builds up with unburnt fuel. The piston goes up and since there is
to much fuel, it can not compress completely and fires then shoots the piston
back down. It will run but badly then stall or it might even change to the right
direction.
NITROMONTREAL is offline   Reply With Quote
Forum Jump
Grande Prairie Model Racers Association WheelNut Canadian R/C Scene 15878 Today 01:12 PM
XRC 1/5 SCALE CARS brewer Australian Racing 3383 11-17-2009 09:21 PM
IDM Products? rcrevolution Exclusive Nitro Engine Zone 612 11-17-2009 06:21 PM
Rc10ntc3 Taz_S Nitro On-Road 9352 08-06-2009 09:52 PM
Help !! Spun new engine backwards Heynow2373 Nitro Off-Road 6 10-28-2007 07:13 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
