Originally Posted by Ralph Walters
The arms come set at zero. So the adjustment range from there is 3 degrees in or 3 degrees out. So yes, you can build rear steer in the car with these arms.
Thanks Ralph, I like to run 0degree toe using the adjustable rear hingepin carriers, but could essentially use these arm's to keep the same axle to axle length but add some rear steer with the adj arm's.
