Go Back   R/C Tech Forums > General Forums > Oval, Larger Scales and More
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 09-16-2009, 09:31 PM   #1
Default dirt oval newb questions
im currently running a brushless slash that i want to pull double duty with - dirt oval runner / trail basher
with that in mind what kind of changes can i make to the chassis and suspension to handle the oval better but still be able to change around for when i go play in the trails
stevelknievel is offline   Reply With Quote
Old 09-17-2009, 03:48 AM   #2
Ovaloldtimer's Avatar
Add some pre-load to the LR shock, and if you can mount most of the gear to the left, if you can mount the battery on the left it will help, also buy an 1/8 latemodel body if your rules allow
Ovaloldtimer is offline   Reply With Quote
Old 09-17-2009, 03:35 PM   #3
thanks buddy! ill get that setup and try tonight! late model body will be ordered as soon as payday comes around lol
Forum Jump
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
