Go Back   R/C Tech Forums > General Forums > Oval, Larger Scales and More
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 09-10-2009, 05:05 PM   #1
Default SC8 for oval?
My local track is starting oval racing in Oct. I have a sc8 and was wondering if it could be converted to oval racing. I already have too many RC's and don't want to go and buy another right now. Will it suffice to get started with to see if I like it?
hairdog is offline   Reply With Quote
Old 09-10-2009, 10:57 PM   #2
Trader Rating: 42 (96%+)
Send a message via Yahoo to loopedout
hmm well the wheelbase is a bit long but the width is right... or swap out for an rc8 plate and center shafts?
Caster Racing USA Dirt Oval Development driver
Schumacher USA
Tekin
Holt Racing Graphics/THD Custom R/C Products/Team Holy Rollers/Team Terribles
loopedout is offline   Reply With Quote
Old 09-10-2009, 11:07 PM   #3
DraftDriver's Avatar
What other vehicles will you race against?
DraftDriver is offline   Reply With Quote
Old 09-11-2009, 06:23 PM   #4
Some late models and other converted buggies.
Old 09-11-2009, 08:20 PM   #5
GSMike's Avatar
I have an SC8 and run the dog out of it. I have not officially "raced" it on our oval, but I have gone out there with others goofing around. If you have light fluid in your diffs (I run 5), you lower your shocks lowering the truck down, and you're pretty good at feathering the throttle you can drift almost the entire oval at full throttle. The down side is you wont be the oval racers' best friend as you'll be slinging dirt from here to forever, but it is a BLAST!
IN HOC SIGNO VINCES
FIDEI DEFENSOR
SC8!!
GSMike is offline   Reply With Quote
Old 09-11-2009, 09:00 PM   #6
I hope more people buy the SC8e it's a fantastic truck.
Old 09-12-2009, 02:19 PM   #7
mxdawg's Avatar
Check out page 21 of the thread show me some oval cars. there is a one on there he might could give you info on converting your buggy.
www.kcracinggraphics.com
mxdawg is offline   Reply With Quote
Old 09-16-2009, 05:10 AM   #8
n10cities's Avatar
Default Use Losi -L8ight body mounts....
I used Losi L8ight front and rear body mounts to convert my BUGGY to a Late Model. See the bottom paragraph concerning the roll cage on the SC8.
On the front, you have to dremel some material off of the main bumper plate so it will fit under the front gearbox after removing the buggy bumper. The bumper has a metal insert so it is not weakened.
Here is a link to our local RC board that has a bit more detail on the construction than the thread here does:
http://www.rc-offroad.net/forum/view...hp?f=34&t=2497
On the top plate, I narrowed mine down to where it would attach at the location of the two top screws that are side by side.
Another local racer did his a different way. He attached the front upper brace to the bottom shock tower mounting screws. Looks a bit cleaner (and stronger) than mine. Here is the thread:
http://www.rc-offroad.net/forum/view...hp?f=19&t=2584
On the rear, you will have to drill mounting holes in the SC8 rear shock tower to attach the rear body mounts. Use screws of your choosing.
Sad thing is, neither of us has had a chance to try out the setup. I am in the middle of a move and I don't know if Tom has had a chance to try his yet either. Been rainy the last week or so.
The only issue you are going to run into is the longer truggy chassis that the SC8 uses. It may not be legal. Will depend on your local track. May not fit right under most Late Model bodies (Stalker, Losi, Ofna, etc)
I just now realized that the SC8 has the big roll cage assembly. You MIGHT be able to get by with just removing the upper roll cage and mounting a LM body to the existing body mount posts! If the rear bumper fits under the body, it would make it more realistic looking and be much stronger. You would just have to borrow a clear LM and do a test fit to see if stuff would work. The front bumper might not fit underneath, but ymmv.
Robbie
www.gshobby.com
n10cities is offline   Reply With Quote
Forum Jump
Lets see some Oval cars!!! hrnts69 Oval, Larger Scales and More 360 Today 12:22 PM
1/8th SCALE SHORTCOURSE CHASSIS DEBATE pete 26 Nitro Off-Road 72 08-20-2009 06:07 AM
New Track @ Extreme Hobby in Hutchinson, Mn arizona82 Minnesota and North/South Dakota Racing 14 07-26-2009 11:46 AM
SC8/COOR style Racing rdcracer Nitro Off-Road 26 01-13-2009 04:09 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
