Go Back   R/C Tech Forums > General Forums > Oval, Larger Scales and More
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 09-01-2009, 11:03 PM   #1
Default 1/10th dirt oval..
Hello all I've seen the losi sliders but remember someone mentioning they were using their AE b4's to run dirt oval. Any suggestions on setups? Seems like quite a few shaft driven 4wd touring cars are used as well..
Any and all recommendations would be much appreciated.. There is also an outdoor asphalt oval close to where I stay as well.. so it would be nice if the cars could double on either asphalt or dirt.. If not no bigge. I have both belt driven and shaft driven tc's. Just want to try soemthing new....
fishnfst is offline   Reply With Quote
Old 09-02-2009, 05:33 AM   #2
lidebt2's Avatar
TC's can not be run on dirt. Not enough ground clearance or suspension clearance.
As for asphalt oval, go to the track and see what they are running. Most are pan cars like the IRS in my signature.
"Blue"
Long Island, NY 360 Speedway R.I.P.
IRS Shock Wave * Tekin RS Pro
www.rcslot.com www.tqracing.com www.teamirsrc.com
Support your local track -- while you still have one.
lidebt2 is offline   Reply With Quote
Old 09-02-2009, 07:06 AM   #3
shawn01's Avatar
I had a tc3 nitro runniing 4 wheel late model limited class for 2 years, they will run on the dirt and are pretty quick even in the limited class.
shawn01 is offline   Reply With Quote
Old 09-02-2009, 07:11 AM   #4
this is false info. tc's are very popular on the dirt. it's the largest class at two tracks in michigan and several tracks from there to florida.
mike
ohio mike is offline   Reply With Quote
Old 09-02-2009, 10:03 AM   #5
lidebt2's Avatar
mike
well I guess i'm wrong. You should know better then me.
"Blue"
Old 09-02-2009, 11:48 AM   #6
AMZ
AMZ's Avatar
TCs on a dirt oval ? That is gonna depend on how bumpy the track is.
If the track is smooth , then there should be no problem.
The first year of our ocal dirt oval track , we ran TCs , and it was too rough.
So , now we run Custom Works Late model GBXs, CW Sprint cars, RC10 buggies of all vintages with LM bodies,and Traxxas Bandits with LM bodies.
All of them do fine.
But- now that the track has "matured" , and is much smoother , we could probably run TCs.
AMZ is offline   Reply With Quote
Old 09-02-2009, 11:25 PM   #7
Thanks for the replies guys.. What am I looking at for a basic starting setup if I was too use one of my TC's?? I remember seeing some fk05's with the offset battery trays and such...
Old 09-04-2009, 05:42 PM   #8
We run TC Late Models at our tracks in West Michigan. As Ohio Mike said, they are our most popular class. The tracks are super smooth and flat clay tracks so the cars kind of drift around the corners nicely. Any rocks or bumpy surfaces take all the fun out of TC Late Model racing.
The shaft drive cars seem to hold up a little better, but a couple of guys run xray 007's and they are pretty fast out there.
We run them with 5" side dams to help them turn, foam tires (custom works) and they friggin fly around the track. On a TC4, Green Springs on the left, Silver on the right. When they are hooked up, they are something to see and race.
If anyones in Michigan next weekend, there's $400-$500 in prize money for a nitro (mostly NTC3's) All Pro 200 race at Dukes Raceplex in Muskegon. Electric racing too, just a special feature for the nitro cars. Should be a thread over on hobbytalk for this one.
kzoolou is offline   Reply With Quote
Forum Jump
Cheese City Dirt Oval Track cheesecityrc Wisconsin & Illinois Racing 201 09-06-2009 05:41 PM
Dirt Oval at Trackside is BACK!!!!!!! Matt Sunderlage Wisconsin & Illinois Racing 354 09-03-2009 04:16 PM
1/10th scale 2wd dirt oval.... shockman Oval, Larger Scales and More 47 07-25-2008 01:10 PM
MIDWEST DIRT OVAL CHAMPIONSHIPS BuckMan Wisconsin & Illinois Racing 55 09-08-2007 08:09 PM
G's RC Raceway in Shippensburg,PA!!! Off-road and dirt oval!!!! IMPACTPLAYR Racing Forum 8 05-14-2006 06:57 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
