Go Back   R/C Tech Forums > General Forums > Oval, Larger Scales and More
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 06-15-2009, 11:43 PM   #1
Mikey D.'s Avatar
Default Dynotech L8ight Towers
Here are some pixs of the new Dynotech shock towers for the Losi that allow you to use sedan shocks. I am using the Losi 10mm shocks you can also use tc3 shocks, I use dubro shock ends and asc. spring cups and tc3 springs.
some of the main reasons for sedan shocks were they are much lighter than the big shocks and the spring options are much better just in the tc3's alone you can go from 12 to 45 lb. but the main reason for me is the shock angle - it stands the shocks up alot compared to stock which really helps you control the chassis roll of the 8 1/2lb car. I reallly like how the balance of the car feels right now. The car works when the track was loose and really good when it has higher bite.
www.dynotech-racing.com
dynotech-l8ight-towers-nashville-018.jpg   dynotech-l8ight-towers-nashville-019.jpg   dynotech-l8ight-towers-nashville-021.jpg   dynotech-l8ight-towers-nashville-023.jpg
Mikey D. is offline   Reply With Quote
Old 06-15-2009, 11:50 PM   #2
Mikey D.'s Avatar
here are some more, if you can't find them on the website just give him a call.
dynotech-l8ight-towers-nashville-020.jpg   dynotech-l8ight-towers-nashville-022.jpg   dynotech-l8ight-towers-nashville-021.jpg
Old 07-17-2009, 08:30 AM   #3
Cestaric's Avatar
Send a message via MSN to Cestaric
Default Body
Helo Micke
what kind of body are you using on your L8 ?
Do you know if a normal GT body is possible to be used on it ?
Cestari
// Cestari
www.gligoco.com.br
Team Losi / Go Tech Engines
Cestaric is offline   Reply With Quote
Old 07-19-2009, 04:03 PM   #4
Mikey D.'s Avatar
I use a losi latemodel body or the C&M latemodel I don't think gt bodies will fit.
Old 08-30-2009, 11:28 PM   #5
Matt Sunderlage's Avatar
Can't wait to get my towers!!!!!!!
Matt Sunderlage is offline   Reply With Quote
Old 08-31-2009, 04:50 AM   #6
Cestaric's Avatar
Default GT Class
Hello guys,
I would like to present you my GT Class.
It is totaly based on the 8ight plataform (it was an old buggy I used to use in the past) with some L8 parts and with a Protoform 1:8 GT Body.
The car is amazing on the pavement. By the begining next month it will in the first race in our local track. The chances are enourmous. During the first tests I've made, it is so much competitive.
Bellow you can see the pictures of my creation (LoL)
Cestari
// Cestari
www.gligoco.com.br
Old 08-31-2009, 06:34 PM   #7
Wow that car looks awesome!!
Forum Jump
L8ight 8&stuff Oval, Larger Scales and More 39 10-11-2009 08:51 AM
IS THIS THE FIRST L8IGHT 2.0 teamslow Oval, Larger Scales and More 15 06-10-2009 07:16 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
