Go Back   R/C Tech Forums > General Forums > Oval, Larger Scales and More
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 05-24-2009, 02:28 PM   #1
Default Narrowing the Losi slider front end
Hey i just bought a used 1/10th scale slider and i'm in the process of getting it ready to race in a couple of weeks. The track i run at mostly run Custom Works and other brands. They also run pink foams all the way around. I have already swapped out my front axles to get the right length needed for my rc4less fronts. I did notice however that the front width is wider than the rear. Has anyone tried to narrow the front end a little to get it 10 inches or lower? I've looked at maybe redrilling the stock front arms or maybe even replacing with some shorter arms from other manufactures. I just wanted to find out if anyone else had tried this?
kdmac is offline   Reply With Quote
Old 05-24-2009, 03:39 PM   #2
If you read some of the Slider threads here and on Dirtoval.com you will find your answer. Looks like many mods have been tried for the front tires.
Brandon Ouellette
braoue67@ctc.net
http://windyhillraceway.com/index.php
braoue67 is offline   Reply With Quote
Old 05-31-2009, 04:48 AM   #3
check the electric thread on dirtoval.com
BigBoyPants is offline   Reply With Quote
Old 05-31-2009, 10:37 AM   #4
Yeah thanks i just looked at that. looks like a great idea.
Old 05-31-2009, 09:03 PM   #5
yfzracer912's Avatar
What are the benefits of doing that?
yfzracer912 is offline   Reply With Quote
Old 06-01-2009, 05:13 PM   #6
Narrowing the front end will increase steering response, but can lose stability. The stock axles are too narrow for regular wheels to fit also.
'Plex Oval Guy is offline   Reply With Quote
Forum Jump
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
