Go Back   R/C Tech Forums > General Forums > Oval, Larger Scales and More
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 04-28-2009, 09:45 PM   #1
rpespo's Avatar
Default Diff fluid
I'm in the process of assembling the FG viscous locking diff. What fluid weight should I be using for 301?
Rich E
Inferno GT1 / LRP Z.28R / "Evo" 2-speed
Monster GT / LRP ZR.30
Spektrum DX3R
rpespo is offline   Reply With Quote
Old 04-29-2009, 08:33 AM   #2
LuisR's Avatar
use the Fg recommended 1000 for cold days and 2000 for hot days.
I sometimes use the recommended oil by VS motorsport, valvoline synthetic oils.
REMEMBER NOT TO OVER FILL THE DIFF. you must only use 20 to 25 ml of fluid.
Oddified RS5 Push-Rod & CR007
FG Short Chassis Porsche
FG F1 Modified Sportline
LuisR is offline   Reply With Quote
Old 04-29-2009, 03:37 PM   #3
vctr1's Avatar
use 17ml of Valvoline synthetic Diff oil 75W-90 , run the car and burp the diff. while the oil still warm. you will be very happy with this set up.
silicone oil changes viscosity a soon that it gets warm. specially on the diff.
VG
Vspeed
FG Evo-08
Xray 07
vctr1 is offline   Reply With Quote
Old 04-29-2009, 04:30 PM   #4
rpespo's Avatar
I can't find the valvoline oil on FG Supply. Where do you get it?
What do you guys use as a measuring device?
Also, VG are you associated with VSpeed engines?
Rich E
Spektrum DX3R
Old 04-29-2009, 06:46 PM   #5
vette09's Avatar
He IS V-Speed motors. Victor's engines are in the cars of some of the fastest guys in the country, including Eric Poholski. Also, remember how fast Scott was all weekend? He took his 4-bolt V-Speed motor out of his F1 and put it in his sedan. Enough said.
Brian
Oddified RS5 Carbon Royale 007
vette09 is offline   Reply With Quote
Old 04-29-2009, 08:12 PM   #6
rpespo's Avatar
Gotcha. I sent him a pm regarding my engine. My car was advertised on ebay as having a Vspeed motor. Maybe he can help with my stalling problem.
Rich E
Spektrum DX3R
Old 04-30-2009, 04:39 AM   #7
LuisR's Avatar
Hey Rich
That 75W90 you cna find on any auto shop (Bepboys, Autozone) not in the FG supply webpage.
This sounds silly but I went to Kmart and got my self a good quality Turkey syringe, the one used to spray fluid inside a turkey. Hey it works!@!@!@!@
Also, this past weekend it was near the 100deg F air temp, and guess what. I was having the same problem you did, my engine kept stalling after a few laps and when I checked the carb bubble it was empty so I kept richining the mix until it did do it. I think I had 1 3/4 on the low and about 2 1/2 on the high, that was crazy. Do you have a hole on the rear of your car??? I am starting to think that our problem (Brian, yours and Mine) are due to not enough cool air coming in and out of the car while on track. All of us have the rear window of our cars NOT cutout and that may be way our engines are getting hotter and then leaning out. i hope VG can chime on this.
LuisR
Old 04-30-2009, 08:21 AM   #8
vctr1's Avatar
Luis is right, you can get the Valvoline diff oil at any auto part store. two things to remember only put 15- 17ml of oil and make sure thta you burp the diff after your first 10 min run. other wise the diif. will build up pressure and will push the out-drives out.
with regards of the motors, a t a 100 degree temp and I assume high humidity? you need to run the motor a little richer; L- 1.3hrs +- H -1.10 to 2.1hrs +-
the carb. bubble need to be a list 3/4 full, if the bubble is not filling up, most like it you motor has a leak. it could be at the base of the carb. or the head. its a lost a vibration on the motor with very little support.
things that I suggest:
1. make sure the the motor has plenty of ventilation, a list open all the side windows.
2. ,make sure that you have a good air filter, clean and oiled. all times.
3. have a good plug, NGK iridium # 7 worlks good.
hope this helps.
Victor
PS: I don't log in very often. Brain has my email address.
Vspeed
FG Evo-08
Xray 07
Old 04-30-2009, 10:10 AM   #9
LuisR's Avatar
hope this helps.
Victor
Thanks Victor,
Rich,
I have a bottle of that valvoline stuff, if you can wait, then I'll give some the next time you come around.
Old 04-30-2009, 10:25 AM   #10
rpespo's Avatar
Originally Posted by LuisR View Post
Thanks Victor,
Rich,
Thanks Luis...I'm gonna try it with some 2000wt FG oil and see how it goes. I want to get some run time in at the station before the next race.
Thanks Victor...I'll email you about the motor. Thanks for the advice.
Rich
Rich E
Spektrum DX3R
Old 04-30-2009, 06:15 PM   #11
Can someone explain what is burp the diff?
vadn1 is offline   Reply With Quote
Old 04-30-2009, 06:49 PM   #12
rpespo's Avatar
The diff has an oil fill plug so I'm thinking loosen the plug after running to let out any pressure that might have built up.
Rich E
Spektrum DX3R
Old 04-30-2009, 07:44 PM   #13
That makes sense, does loctite need to be used on that plug?
Old 05-01-2009, 07:33 AM   #14
rpespo's Avatar
The instructions do not call for it. It comes with a brass washer. On Luis's advice, I went to WalMart and bought a plastic "flavor injector" to add and remove the diff oil. It's basically a big plastic syringe used to inject liquids or seasoning into meat. It works great! It even has measurements on the side. Thanks Luis!
Rich E
Spektrum DX3R
Forum Jump
Tamiya F103 Forum TFR Electric On-Road 817 Today 05:56 AM
Team Magic G4RS 2009 gtrmx Nitro On-Road 911 Yesterday 02:56 PM
Diff fluid pinky2252s Nitro Off-Road 11 04-30-2009 02:27 PM
Losi 8T diff question grease/fluid broke it again Nitro Off-Road 7 04-13-2009 05:54 PM
Help with diffs bigblockbuggy Electric Off-Road 11 12-11-2005 11:27 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
