i was wondering if someone could give me advise on what tires to run on a very high bite asphalt track, and a low bite concrete track? both are ovals. i currently run 28mm foam tires on the left side and 30mm foam on the right. the tires seem to wear out after about 3 hard runs on the high bite track, and it seems like i cant get enough grip on the low bite track with them. also, if it matters, they are from bsr-racing. if need be, you can contact me at
joseph.brown@chesterfieldpolice.com
thanks in advance,
joey
