Originally Posted by bige
This sounds awesome....what classifies the late model spec?
Rule's and Race are by Family RC and Mike Ottinger, I pasted this here
1/8 LM classes for 2009
Sportsman Late Model Spec:This class will have some limits on who can run in it. If the track deems you should be moved they have the right to do so. The same three motors as always.(RB S3 LG2-NR BF2001-OS VG or RG) NO MODDING! No side dams and molded bodys. 3" max rear spoiler with the side dams no higher than the rear spoiler at the rear and 1" at the front leading edge. 3" from the base of the spoiler to the front edge. It must be a triangle shape. Weight of 8 1/2 lb.
Foam tires only
Late Model Spec: This class will have some limits on who can run in it. If the track deems you should be moved they have the right to do so. The same three motors as always. NO MODDING! No side dams and molded bodys. 3" max rear spoiler with the side dams no higher than the rear spoiler at the rear and 1" at the front leading edge. 3" from the base of the spoiler to the front edge. It must be a triangle shape. Weight of 8 1/2 lb.
Foam tires only
Open Late Model: Any 1/8 scale style Motor. Side dams 5" tall from top of deck, 4" back from the left front center hub and can't go past rear of body. Molded bodys only. 3" max rear spoiler with the right side dam no higher than the rear spoiler at the rear and 1" at the front leading edge. 3" from the base of the spoiler to the front edge. It must be a triangle shape. Weight of 8 1/2 lb.
Foam tires only
General rules:
4min heats and 4min mains in all classes for weekly racing
Wheel base and width TBA
Must be a GTP and /or buggy based.
No one off cars. All cars must be production based.
No parts can sick out past the tires more than 1/8 in.
The track has the right to determine what is legal.
You must go though tech before racing.
A car found illegal in post race tech is your falt and will be DQ'ed
Spec motors will be teched at random.
Top three A-Main cars and motors will be teched at big races.
All classes will be teched at random each week.
Any motor found illegal post race would be hit with a hammer!
No kidding! If you don't want to lose it, don't run it!
This is a work in progress for now. The rules will be in stone soon.
