Go Back   R/C Tech Forums > General Forums > Oval, Larger Scales and More
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 12-29-2008, 08:13 PM   #1
Default Stripped Hex screw(s)... HELP!
Okay I was trying to change the diff and I had 2 stripped hex screws.
What can I do?
I bought a new set of allen wrenches but working with alloy parts some of those screws have a bite to them and cant get them out.
Any sugesstions?
Theres got to be a way...
This cant be the end!
H
E
L
P
talentsearch301 is offline   Reply With Quote
Old 12-29-2008, 08:20 PM   #2
myrxseven's Avatar
Easiest and most effective way would be to dremel a horizontal or vertical(doesnt matter which one) groove into the head of the screw for removal with a flathead screwdriver.
CRC Gen XL 17.5 1s Lipo
Spektrum l Novak l Tekin l SMC l Jaco
myrxseven is offline   Reply With Quote
Old 12-29-2008, 08:26 PM   #3
sheetmetal2's Avatar
Default screws
What he said but don't to scared if you get the part a little with the dremmel. Not a big deal. If you are using the quality hex wrenchs make sure that the hex socket is completely clean of all dirt. That seems to be the culprit every time.
www.rcxracing.com
Rc10 Gt EDM
M&M Racing Klien Sprint Car
Losi Mini T
sheetmetal2 is offline   Reply With Quote
Old 12-30-2008, 11:29 AM   #4
thanks guys!
Old 01-01-2009, 04:23 AM   #5
If the screw has Loctite on it you may need to apply a little heat. The tip of a soldering iron will help.
zrcman is offline   Reply With Quote
Old 01-01-2009, 05:57 AM   #6
kmh
I have found it best to invest in a screw extractor set. The dremel idea works pretty good but, sometimes the diameter of the cutting disc causes you to cut beyond the screw head leaving cut lines in the area around the screw,i.e. the chassie, or a screw that is countersunk.
kmh is offline   Reply With Quote
Old 01-01-2009, 07:12 AM   #7
Trader Rating: 28 (100%+)
Get yourself a cheap set of the smaller Torx (star shaped)
driver bits. Pick one that is just a hair bigger than the
the stripped hex hole and drive it into the screw with a
small hammer. Slide your handle onto the bit and push
down on the bit as you turn the screw out.
rageworks is online now   Reply With Quote
Old 01-01-2009, 10:12 AM   #8
I have found in a tight situation a pair of diagonal cutters (dikes) can get a stripped allen head screw out. Stick the point of one side in where the allen wrench goes and the other point on the outside. Give a good squeeze and spin. The points dig into the screw real good. I have used this technique many times at the track when no Dremel has been available.
jozimoto is offline   Reply With Quote
Forum Jump
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 2824 Today 04:21 AM
kyosho electric offroad b-man777 Electric Off-Road 8867 11-18-2009 05:45 AM
SAVAGE - SS, .25, .21 Official Thread! Horatio Monster Trucks 11104 09-09-2009 10:44 PM
TRF414M, 404x, 414, 414X TRF-Powered Electric On-Road 3306 08-27-2009 11:49 AM
Truggy Shootout RUF-VK Nitro Off-Road 102 04-30-2009 01:09 PM
Need Help With Losi xxx-s Kit NeO-pRo-3 Rookie Zone 10 01-01-2003 09:06 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
