Ofna GTP
#16
#17
#19
#20
I am interested to join the GT class....now, I have 3 choice...
OFNA GTP (new version)
OFNA DM1
Kyosho IGT (old and new version)
I am more toward the GTP because I am not sure Kyosho has any good parts support...and GTP RTR is cheaper, everything (parts) are cheaper, easy to get....DM1 is off the scale a little and might have some unfair advantage...IGT has no problem except parts support..
Anyone can share idea...? Thanks...
P.S...what are the good TIRES for GT class..? Some said Kyosho with off road insert stuff in...but I know there are several GT class tires premount for sale now...which one is the everyone favorite..?
OFNA DM1
#21
OFNA DM1
OFNA DM1
#22
OFNA DM1
OFNA DM1
#24
#26
#27
OFNA DM1
OFNA DM1
I'll share with you what I have found:
There is also the DM1S, which is a shortened version of the OFNA DM1 car. It is the same length as the GTP and IGT (not IGT2) version. It has the horizontal shocks and from what I have been told has better diffs and other parts than Ofna GTP 2 (new version). The DM1 S comes as a kit (around $350) with no engine, but front and rear pivot ball suspension and blade sway bars.
The Ofna GTP II would be the next lower level, it has front pivot ball suspension, Force .28 engine, clutch type 2 speed etc. There is an optional rear pivot ball kit which included blade sway bars.
The IGT has three weak points, clutch, transmission and engine. Not all users experience the weak engine bearings. The transmission 2 nd gear catch mechanism may last if you set it to shift shorty after the clutch engages, other than that I have had mine wear out after a day of racing, say 3 qualifiers. The stock clutch not worth keeping for racing. If you want to race and not wrench replace the transmission with one from the Ofna GTP II. There is also the possibility of using Evolva 2-speed parts. Some racers have had good reliability from this car. A lot have not. And you need to upgrade the brakes. You raced in the MWS racine race, you need the optional metallic brake pads for high braking areas, like the end of the straightaway.
I have not seen a new IGT on the shelf, so I cannot comment on any improvements.
I am racing with the Inpanema belted slicks. They offer excellent grip and wear. LHR has them in stock. You may also want to try the Ofna belted slicks. There are many other tires available.
Ken
#28
#29
I see where youre saying use 10,000 in the front diff, is this just on the GTP?
I've been reading other posts where 120,000 front, 50,000 center, and 1000-3000 for the rear is what is wanted. Is this just for cars with center diffs. I run a Jammin that i've really got interested in running oval instead of offroad so oval setups are completely new and confusing, but thanks to here and Dirtoval.com have helped greatly.
The above setup is what i'm currently converting to, but what about springs and stagger?
As far as converting to LM, the front GTP bumper, bumper foam, and mounts are whats needed.
Thanks for the great info.
#30
Howard,
Ken
Ken
Thanks for that detailed information Ken.........by seeing the GTP II and Force 28 running last night....I was sold. GTP II that is....the car is solid enough for me without any major modification....all I need are some Inapnema Rubbers, a more race looking Protoform 1/8th GT body...then I am ready to hit the track.
There is something I don't understand...OFNA site or Tower has any of those GTP II information listed at all...like the GTP II never exist when there are ppl running around on parking lot everywhere....can't even find more detail or pictures about that.
Ken...I will see you next week....and that will be my debut of GT class as well, I always want to race Walt....and finally I have something for him to race for (I am using a loaner prototype car that I dont' even know what that is....LOL)
