3Kg R/c sumo robot
3Kg R/c sumo robot
Does anyone have some ideas how to make simple and durable sumo contest robot. I have all electronics and all stuff needed. It`s due september 12 and must be not larger than 20x20 height unlimited.
Yeah, here is what you need.
4 55turn lathe motors & 2 escs that can handle a large load that also have reverse.
Now take a piece of sheet metal & cut out two motor mounts about 3 inches from the front & back. Your going to repeat this process for the other side. Now frame the two pieces togather 20cm or what ever apart. Then mount up some tiny tires & add your battery.
