Go Back   R/C Tech Forums > General Forums > Oval, Larger Scales and More
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 05-07-2008, 06:48 PM   #1
Default what to get
i am looking for a good engine for a 1/8 scale late model oval car is a gtp
sfd.405 is offline   Reply With Quote
Old 05-07-2008, 07:54 PM   #2
eazy_greezy's Avatar
I run LRP .28 very nice engine 189.00
eazy_greezy is offline   Reply With Quote
Old 05-09-2008, 06:46 PM   #3
ok thanks are hard to tune. i am new to racing .
Old 05-09-2008, 09:46 PM   #4
no pretty simple go through the proper break in procedure.. it say to lean as you go though a tank i keep it rich the whole 4-6 tanks with a rag around it to get it up to temp then just get the top end tuned and just a couple ticks on the bottom end.....i have mine rich so i got about 3 turns on the top not sure about the bottom i have it as rich as i can have it as long as it clears out and ideal fine a good tuning technique is to have the top end set first and to tune the bottom end do the pinch test, pinch the fuel line if it cuts off to 2-4 sec its to lean on the lSN. if it shuts off longer then about 7 seconds to rich as long as it shuts off in 5-6 sec and clears out without a bog its ready to rock.You'll like the engine plenty of power its an 8 port with 4hp. good luck
Forum Jump
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
