120,00 weight diff oil in the front
3,000 or just grease in the rear diff
60-80wt front shock oil
50-60wt rear shock oil
1 degree negative camber on the right side
1 degree positive on the left side
Stiffen the sway bars as much as you can
May possibly need stiffer springs to control the chassis roll depending on the grip level at your track
