what oil weight do you recommend using on the shock absorbers for the F1 car on a high grip surface track?
Thanks,
LRR
Which F1 do you have and what springs/tires are you running? I have the comp with the MMR chassis and the MMR gear drive set. I run 4000 in the front. Only time I mess with it is when the track is obnoxiously slick like SV recently.
Associated B44 - MurfDogg 7.5 Reedy 5100 LiPo
FG 1/5 Scale Formula 1 - Molzer Mowery Racing
do you have the reactive rear MMR Toe conversion on?
www.molzermoweryracing.com
MMR Direct Minnesotas Premier Indoor Race Facility
North American Importer/Distributor Factory Support for FG, Modelcargo, Serpent, Samba, FF Concepts, RayWood Videos
What is that???
I have been experiencing "oversteer" on my F1 car for a while now. I don't know if it is tire related, as I have "C" tires on the rear and the temp hasn't been to great either. Anyhow, I thought about changing the oil weight on the shocks to change the timing on the weight transfer. I have soft springs on the rear and stiffer in the front. The sway bars on the front are almost at max HARD setting and very soft in the rear.
Any idea?
