unorthodox suspension setup..pleaze look
this is an ongoing problem that i could use some help with.. my butt comes around my head..serously. when entering a turn tha back end comes around.out of the hole shot it hooks up sweet. on power streering is great for a 2 wheel drive buggy. i dropped the back end down so its lower then the front, and use tire traction wich helps for a little bit.. should i lower the shock oil wieght or the shock piston.out of the 5 piston holes, im on the smallest 1(its hyper-adjust). but my front left tire comes off the ground as it is.. so if i go any lower, it will get worse. what if i put on a heavier spring? have many.. im set at 2* with my rear toe-in will a zero toe-in help.. im also running light diff oil. i think if i go heaveir it will be even worse.?. PLEASE.. any tips will help.. this is a 1:5 hpi 5b.. its all the same, just bigger
SORRY, WASNT CLEAR.. THIS IS A 5B ON-ROAD....
hpi 5b on-road, hpi rs4 evo, hpi rs4-3....
