Go Back   R/C Tech Forums > General Forums > Oval, Larger Scales and More
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 03-04-2008, 07:41 PM   #1
Trader Rating: 15 (100%+)
Default gearing help
tc4, 19t, 400' runline dirt oval, where would you start for gearing. im using the stock 72 tooth spur and i have a 75 in the box
thanks for anyhelp
VenturaDC is offline   Reply With Quote
Old 03-04-2008, 08:50 PM   #2
if I were you I'd start out running what you have installed, and see what you think. From there you should be able to gauge whether you should gear up or gear down and determine from your impression on where to go. I would also take a look at how your car performs compared to others and ask them what they are running if they are running a tc4 as well. That's just what I would do. I think the 72 is a good starting point and it's not worth switching the gear out unless you know it won't work.
Brandon
oceanhighz is offline   Reply With Quote
Old 03-04-2008, 08:58 PM   #3
well the thing is that i dont have anything installed yet, im not even sure where to start out for gearing a 19t in a tc4 in general, i did some google searching but mostly found threads about brushless gearing.
Forum Jump
Gearing lickashotblaow Electric On-Road 0 07-29-2007 04:47 PM
NeeD Help with gearing please daver1 Electric On-Road 4 07-20-2007 08:12 AM
Gearing for TT-01 tl-01-jhb Rookie Zone 0 11-10-2004 04:35 AM
Need help gearing a TC3 fasda1 Electric On-Road 10 11-06-2004 10:51 AM
Gearing??? mike m Monster Trucks 3 01-24-2004 06:54 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
