Originally Posted by losi god
to get 0 degree toe in rear u need to get 0 degree rear pivot blocks
I am using them right now. part # LOSA2112. and there is absolutely no change in the toe in or out. and I also have the 0 degree hubs. tried them both left and right. still no change in toe. (I almost think they had the wrong part in the bag because there is no difference to the stock one. except the new is a bit wider)
I just got back from racing a few minutes ago. I tonite I tried slightly longer shocks. I took some traxxas 4 tec shocks with the longer shaft installed instead of the TC3 shocks that i had on it.
I moved the rear shock mounts all the way out on the bottom and all the way in on top. (using the speedys oval conversion towers). I'm not sure what springs they are but they are the softest things I could find.
the front i kept in the middle on the bottom but moved the front out so they are straight up and down, with the traxxas 4tec white springs. 30wt oil on all 4.
Wow what a change! glued to the track. I dont think I have ever had a better handling car ever.
sure would like to hear some more on the rear toe.
