Wow. That setup he posted is very hard to drive. More like this on a FG:
Front:
springs blue with no curve on the spring(FG´s)
(test blue springs before you test yellow or purple springs)
Shock oil: 8000 or 9000
Height: 7mm - 9mm
Camber (hold down) 1 or 0 degress, The wheels should stand like it had negative camber in front when youre not holding it down.
Toe-Out: about 0,5 to 1,5 degrees
Tires: GRP New C or GRP A Always! I recomend GRP NEw C with better traction and lasts longer.
Rear:
Springs Orange with curve on the springs(FG´s)
shock oil: 5000 or 6000, maybe 7000
Height: 8mm - 11mm
Camber (hold down!) 2 degrees on the outside of the wheel.
Toe-In: 3 degrees
This setup works with all tractions on tracks! i think you need softer setup for a parking lot.
This setup works with weather sunny up too 30 celsius then maybe you should change more camber, harder suspension.
Coldest will be around 17 celsius then you must have a softer setup.
This setup works almost everywhere. Here in sweden and Denmark where we have really good drivers drive often with similar setup to this!
