Go Back   R/C Tech Forums > General Forums > Oval, Larger Scales and More
Old 07-04-2013, 03:52 AM   #1066
M7H
M7H's Avatar
http://www.youtube.com/watch?v=q-OqhU6WF3o
Topspeed was 106.2 kmh
laptimes the same as nitro.
Serpent
M7H is offline   Reply With Quote
Old 07-04-2013, 02:15 PM   #1067
Trader Rating: 26 (100%+)
Great video!
Can you post some photos and list more about the car? eg. battery type/size, gearing, speed control settings etc.
CountryHick is offline   Reply With Quote
Old 07-08-2013, 03:58 AM   #1068
M7H
M7H's Avatar
That's the car.
http://sdrv.ms/18M6jc1
Standard 966e, with custom made radioplate and under plate for equipment.
ESC: Tekin RX8
Motor: Redline T8/1900KV
Lipo: Rhino 6S/4000mAh/25-35C (109x34x83mm)
5.30 runtime.
Car weights 150 grams more then a nitro with full fuel tank.
Pinion 21T
Spur 46T
ESC settings:
Drag brake: 1 (no drag brake)
Brake strength: 6
Limiter: 1
Neutral width: default
Cuttoff: 6S
Motor type: BL-FW (Brushless, forwared only with brakes)
Throttle Profile: 3 (Lineair)
Serpent
Old 07-14-2013, 12:07 PM   #1069
M7H
M7H's Avatar
Took off the typical 8th scale body, put on a 8th scale McLaren GT body, went 1 tooth up on the pinion, and this is the result!
http://www.youtube.com/watch?v=F6YtRurrv0Q
Runtime 7 minutes.....
Topspeed 114kmh
Serpent
Old 07-14-2013, 08:22 PM   #1070
Trader Rating: 14 (100%+)
Great work! Is this the body you used?
http://www.nitrohouse.com/OFNA-DP8-18-GTP-Body-Clear_p_6806.html
Speedpassion : Speedpower : East Coast Bodies
thunderbt3 is offline   Reply With Quote
Old 07-15-2013, 12:27 AM   #1071
M7H
M7H's Avatar
Originally Posted by thunderbt3 View Post
No.
The body I used I still had from the Serpent Nitro Tour, from 10 years ago.....
A 8th scale car has a wheelbase of 300mm...
This body will fit.
http://www.amainhobbies.com/product_...smo-Body-Clear
http://www.motonica.com/en/products/BODY_8
Serpent
Old 09-01-2013, 12:10 AM   #1072
FF25510's Avatar
hi all,
in what tyres diameter/size without changing the pinion the car can handle. also does handling difference from fresh tyres to the smallest ?
thanks
FF25510 is offline   Reply With Quote
Old 09-01-2013, 12:54 PM   #1073
Awesome looking car and track. But, I have to ask, don't you get tired of running the exact same layout all year, year after year?
Serpent SRX8 electric
Serpent Cobra 811TE-E
Serpent S120LTR 17.5 1/12th and S100LTR Pro-10
Serpent S411 Eryx 4.0 USGT
Team Serpent America and Desoto Racing
Stealth_RT is offline   Reply With Quote
Old 09-01-2013, 02:46 PM   #1074
DS Motorsport's Avatar
This weekend we finally had the shakedown of our 1/8 electric car.
I think the amount of power is 90% there, just need a little more topspeed.
Now we can focus on improving the handling, you can see in the video it's nose heavy which causes a lot of understeer.
A new design to cure this has already been made and hopefully we can test this within two weeks.
+ YouTube Video
http://www.youtube.com/watch?v=7dwDdRAz1gk
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 09-11-2013, 08:56 AM   #1075
Pascal Brun's Avatar
Send a message via Skype™ to Pascal Brun
Hi DS Motorsport,
do you have already revised you car design for more steering?
If you need more topspeed you can change the gearing.
Pascal Brun is offline   Reply With Quote
Old 09-12-2013, 01:22 AM   #1076
M7H
M7H's Avatar
Originally Posted by FF25510 View Post
hi all,
thanks
I run the car with a roll-out of around 45mm, depending the tyre diameter, I change the gearing to get around this 45mm.
The car handles great, until I run out of front tyres.
In my case, because we don't race these cars yet, I use left over tyres from my nitro car.
Serpent
Old 09-12-2013, 01:24 AM   #1077
M7H
M7H's Avatar
No, not really, or actualy really not!
I run the 8th scale nitro nationals also, so I run on different track anyway.
The nice thing about the same layout, is that you really can compare week to week, or even year to year, If you are faster or not.....
Serpent
Old 09-23-2013, 10:57 PM   #1078
new track record in Türkheim (Germany) with a Mugen MRX5 TTB prototype
go to:
Platzhirsch.net
fastest time 11.795 electro 1/8 Christoph Pitsch
fastest time nitro 12.063 Eric Dankl
www.ttb-rc.com
www.tectrade.ch
info@tectrade.ch
Old 09-24-2013, 06:15 AM   #1079
go to:
Platzhirsch.net
Any chance you could post more and bigger pictures? The picture on the website is pretty small.
Old 09-24-2013, 08:43 AM   #1080
Hi David,
I'll update the pictures asap. the rollout was this Sunday...and I've only some older pictures without motor/controller an lipo.
Christoph has to rework some prototype details...I'think after some modification -and with a higher grip level- the track time will go down again (11.49 should be possible)
If the grip level is high you should be 0.4 till 0.5 seconds faster than the nitro 1/8 cars
www.ttb-rc.com
www.tectrade.ch
info@tectrade.ch
WTT Nitro onroad 4 electric onroad rswartz R/C Items: Wanted to Buy 0 02-16-2008 05:22 AM
WTT: 1/10th scale electric offroad for onroad... M2_Driver R/C Items: For Sale/Trade 7 10-22-2007 06:48 AM
Electric heli and 1/5 scale onroad F/S... Nitrobuzzard R/C Items: For Sale/Trade 3 08-18-2007 07:41 PM
1/8 electric onroad?? Saber186 Electric On-Road 2 04-22-2006 10:25 AM
I need electric Onroad xxxssportracer R/C Items: Wanted to Buy 5 05-20-2003 04:00 PM
