Go Back   R/C Tech Forums > General Forums > Oval, Larger Scales and More
Old 12-14-2012, 07:21 AM   #1021
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by AdrianM View Post
It will take off and fly.
It will be fine.
I guess the motocycle helmets from the offroad worlds will come in handy then
Old 12-14-2012, 07:27 AM   #1022
howardcano's Avatar
Trader Rating: 35 (100%+)
We might also need cages for the marshalls, like the pylon plane racers use.
Many years ago when racing 1/8 gas in Colorado I witnessed a car launch on the straight and hit a marshall in the back (he was watching the turn at the end of the straight). He was a big guy-- not one that you'd want to piss off in a bar. He was down for about 5 minutes. Fortunately, no permanent damage was inflicted!
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 12-14-2012, 12:24 PM   #1023
DS Motorsport's Avatar
The system shown by Veloxrc will be the future for electric 1/8 onroad, it's the only system which is able to provide eletrical power equal to a nitro powered model reliably. All the current offerings from the well known brands aren't designed for 1/8 onroad power and all fail when you want to run them on 6S power.
The system doesn't use a sensor because it isn't reliable with the high currents and magnetic forces developed by the system. As mentioned the system uses a very smart dynamic timing system which automatically applies timing based on load and rpm.
Also the system has a 'kers' function, it's able to store it's braking energy and use it again for hard acceleration, this protects the battery.
I've been working for more then a year on a conversion based on this system, as a base I will use the Capricorn LAB-C801.
Here some renders:
It took a while to get the correct carbon fiber for the chassis, I finally have the type I want and all the carbon fiber parts will be finished this month.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 12-14-2012, 02:12 PM   #1024
howardcano's Avatar
Where does it store the braking energy if it's not in the battery?
Howard Cano
Old 12-14-2012, 02:20 PM   #1025
It has three super-capacitors to store the energy, same technology as used in F1.
P1-RC.com
Old 12-15-2012, 08:52 AM   #1026
YoDog's Avatar
Trader Rating: 26 (100%+)
Beautiful renders!
Are you using SW? I especially like the red anodizing.
I thought mine were good but you apperently have your rendering settings dialed.
YoDog is offline   Reply With Quote
Old 12-15-2012, 09:04 AM   #1027
YoDog's Avatar
Originally Posted by 2wdrive View Post
Why make a 1/8 scale pancar when you can buy a 1/10 scale 235mm pancar (pro10) and be done?
A pro10 will be lighter, can drive more comfortable on smaller circuits and is fast. A pro10 with lola, 2s with 7t delta will have more corner speed and acceleration then many can handle comfortably. Everything is already there if you want to drive a pancar really really fast.
(German Masters pro10 2012)
+ YouTube Video
(German Masters pro10 2009)
+ YouTube Video
I tried that... The car felt so tiny out on the 1/8th track. Sure it's fast but didn't feel safe. I just got tired of all the problems associated with the conversions and wasn't having any fun anymore. I feel that something simple, less expensive and comfortable was what I am looking for. This is why I changed direction toward the pan chassis. Besides I needed a way to use up all my old 1/8th foam tires that are too small for my nitro car.
Old 12-15-2012, 09:15 AM   #1028
YoDog's Avatar
It will be fine.
I hope I will never prove your theory correct.
I'm not looking to blow away the nitro cars, at least speed wise. I just want it to be fast enough to be fun and somewhat inexpensive. I'd like to get more racers to the track, not scare them away with something dangerous. If your average 1/8th or 1/10 TC driver is compelled to try something very different and new, like a pan car of this type... I think it would be a lot of fun. That's what hooked me on WGT. Unfortunately, our local carpet track is now gone.
Old 12-15-2012, 09:44 AM   #1029
howardcano's Avatar
I think you'll find that other drivers will donate their old tires, too. I ran 1/8 pan nitro for quite a while without ever having to buy rear tires!
Howard Cano
Old 12-15-2012, 09:52 AM   #1030
2wdrive's Avatar
Yodog, ok I can see that it would be nice to reuse the tires. Overhere you can buy an adapter to run 1/10 nitro foam tires on the front of a pro10.
www.rc-lemans.de
2wdrive is offline   Reply With Quote
Old 12-16-2012, 01:40 PM   #1031
Beautiful renders!
Thanks!
Yes, I use Solidworks for the design and the rendering.
I use the separate photoworks application, not the one build in.
For the red alu parts I use the 'gloss red car paint' material. All settings bumped up to max and then you get that kind of quality.
However I must say your renders look very good as well, especially the carbon fiber. The carbon motif looks a lot more realistic, mine is too gray looking.
P1-RC.com
Old 12-16-2012, 06:01 PM   #1032
D.a.v.e's Avatar
Seems like we need a nice quick change battery system included in this next generation. I want to be able to run some longer mains!
D.a.v.e is offline   Reply With Quote
Old 12-17-2012, 08:17 PM   #1033
rangerjkb's Avatar
Trader Rating: 36 (100%+)
Send a message via MSN to rangerjkb
Racing 1/8 E Buggy offroad has tremendous power and great reliability, would absolutely love to see what a purpose built 1/8 Onroad car could do....would be some crazy speeds!
Jason Burks
Murfdogg Products~Psycho Cells Racing~Hal's Hobby Warehouse~Avid RC~Kal-Gard~VP Powermaster
rangerjkb is offline   Reply With Quote
Old 12-17-2012, 09:46 PM   #1034
YoDog's Avatar
Thanks!
For the carbon, I select a dark grey colored base when selecting the carbon in the appearance settings. This helps to reduce the silver appearance.
So, the stand alone photo360 is better? I used that with 2010 before it was integrated. Maybe I should try it again.
Old 12-18-2012, 11:46 AM   #1035
NDZ
Yodog, do you have bulkheads and rearaxle + hubs available yet? Or do you have/make custom ones? Especially the diff is interesting. Are planning on using 48pt? Also using the quick release system is an option maybe? Love to see some updates if you have em. Hope your design will succeed.
NDZ is offline   Reply With Quote
WTT Nitro onroad 4 electric onroad rswartz R/C Items: Wanted to Buy 0 02-16-2008 05:22 AM
WTT: 1/10th scale electric offroad for onroad... M2_Driver R/C Items: For Sale/Trade 7 10-22-2007 06:48 AM
Electric heli and 1/5 scale onroad F/S... Nitrobuzzard R/C Items: For Sale/Trade 3 08-18-2007 07:41 PM
1/8 electric onroad?? Saber186 Electric On-Road 2 04-22-2006 10:25 AM
I need electric Onroad xxxssportracer R/C Items: Wanted to Buy 5 05-20-2003 04:00 PM
