Go Back   R/C Tech Forums > General Forums > Oval, Larger Scales and More
Like Tree1Likes
Old 07-20-2012, 02:23 AM   #901
SuperEk4's Avatar
Trader Rating: 32 (100%+)
Originally Posted by tjompa View Post
Thanks for the replies guys.
I didnt feel that my car handled like crap, i was not very used to driving it at that point, when i managed to put the car in correct apex i had almost the same laptime as the nitro guys. if you look at the laps approx 1.50 in the movie i started to get hang of it.
I guess gearing was to high and i have no slipper, but i was told to get two 5S packs and a 1000kv motor to be on the right side with the electronics. weel maybe i will build this one as a speedcar.
I guess 4S is not an option, i want to go fast so next year i will build a 1/10 235mm pan car instead.
what's gearing n batt mah?
Hobbywing-Acorn Racing-ManiaRC-UpgradeRC-Hong nor-Rc monster-Blackbeard-Rc-MoosDesign-SweepRacing-Boca bearings-Tresrey USA-Velociti raceware-Tekno Rc-Team J-JPL Models-SNR Graphite (RETIRED)
SuperEk4 is offline   Reply With Quote
Old 07-21-2012, 01:28 PM   #902
Just finished adding cells to my Evolva. Got heavy-all up weight,6lbs,1oz. Don
Will there ever be a 1/8th scale Electric onroad car-p1010001-15.jpg   Will there ever be a 1/8th scale Electric onroad car-p1010002-15.jpg   Will there ever be a 1/8th scale Electric onroad car-p1010003-14.jpg   Will there ever be a 1/8th scale Electric onroad car-p1010004-11.jpg
DLS II is offline   Reply With Quote
Old 07-21-2012, 03:17 PM   #903
SuperEk4's Avatar
nice.direct drive? what batt are those?
Old 07-21-2012, 04:29 PM   #904
Thanks. Drive is the usual Evolva setup.(direct in rear,one ways up front and 3 belts)The batts are A123 26650 cells. 3.3 volts nominal,2300 mah ea. Configuration is 4s2p. 13.2 volts 4600 man. Don
Old 07-21-2012, 04:51 PM   #905
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Originally Posted by M7H View Post
I did.
But if it was the ESC or the motor, which in return fried the ESC, I will never know.
After the ESC went, I replaced it for a new one, and it immediately broke after switching it on. Turned out to be a damaged sensor board in the motor.
After switching from 6S lipo to 4S, I never had a problem like that again, other problems occure then
As you can see in your first movie in where you drive together with some nitro 8th scale cars, you can see the big disadvantage of driving 6S lipo, mounted next to the car, it handles like crap. The weight is around 500grams more, and hanging on both sides of the car, giving the car to much roll....
My 4S 966e handles almost like his nitro powered bigger brother (I still believe nitro powered is the bigger brother )
But the problem with 4S lipo, is runtime. I have not yet been able to go flat out and reach 5 minutes.
Stories I read here about 8 minutes runtime, might be true on a small track, bur running at the MACH track, a real 8th scale track, like we have a lot in Europe, is a real challenge, atleast, if you also want to have some decent topspeed.....
i have tried alot as well.
one H/W ESC one RX8 . 6S and 4S 2650KV to 1950 KV.
i have settled for RX8 on 4S , Orion 1950KV motor, 6500 70C 2S packs in series to make 4S. gearing 24t pinion, and 44T spur. top speed needs to improve, but to race for 5 mins and push hard from start to finnish is not a problem here. its also on a large track, even though top speed from EP tourer is down maybe 25k/hr, the lap time is 1 sec faster, and on overall time that makes for about 1.5-2 laps faster than EP touring Mod.
although i have settled for this, i am still thinking about other ways to run . but its all time and money. after October here, when our Gas Nats are done, ill look to try some more things. but generally if you want to run 6S, id be looking at 1700KV or lower. 4S around 2000KV, these seem to be safe as far as not burning out your gear.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 07-21-2012, 06:22 PM   #906
SuperEk4's Avatar
how fast can it go? what's the gearing?
Old 07-22-2012, 04:41 AM   #907
At the moment the FDR is 6.48 to1. I plan on going to 5.4 to 1 by changing the pinion to a 24T. It's fast but I have no real way to know how fast. Don
Old 07-22-2012, 04:51 AM   #908
i own a serpent 960 converted to electric too. will post pictures later of my setup .but now my question is different : who think its worth to install a gyro on 1/8 scale and why ?
dgomes is offline   Reply With Quote
Old 07-22-2012, 02:52 PM   #909
M7H
M7H's Avatar
I know.
I'm still trying to use the standard saddlepack layout, but i think I also need to go to a 2x2S lipo layout (like your car), because of lipo capacity.
All in time...
I'm also testing the 4S lipo powered F180, really nice!, and the GT.
And at the moment I'n running the 12th scale worlds......
Serpent
M7H is offline   Reply With Quote
Old 07-22-2012, 03:38 PM   #910
SuperEk4's Avatar
why not 6s n how does it feel running 1 way vs ball diff in the front? I just brought a front 1 way.
btw my car is 9-10 years will my belt snap lol
Old 07-22-2012, 07:08 PM   #911
Hard braking brings the rear around immediately. I wish the Tx or SC had real antilock braking. Turn in is quick vs a ball diff. I couldn't figure a way to mount a 6s A123 pack. I'm going to run it again after I regear it. The motor is a Novak 7.5 HV. I thought it best to stay with 4s. Don
Old 07-24-2012, 12:37 AM   #912
SuperEk4's Avatar
a123 cells are heavy.y not lipo?
Old 07-24-2012, 01:49 PM   #913
Bugstomper's Avatar
They have a 1/8 electric on nitrorcx
Nikko Mystery Car
Built a Tamiya Frog
Bugstomper is offline   Reply With Quote
Old 07-24-2012, 04:01 PM   #914
A123 cells are more robust and more tolerant of abuse. And I have a bunch on hand. Don
Old 07-25-2012, 07:37 AM   #915
SuperEk4's Avatar
they are heavy too
WTT Nitro onroad 4 electric onroad rswartz R/C Items: Wanted to Buy 0 02-16-2008 05:22 AM
WTT: 1/10th scale electric offroad for onroad... M2_Driver R/C Items: For Sale/Trade 7 10-22-2007 06:48 AM
Electric heli and 1/5 scale onroad F/S... Nitrobuzzard R/C Items: For Sale/Trade 3 08-18-2007 07:41 PM
1/8 electric onroad?? Saber186 Electric On-Road 2 04-22-2006 10:25 AM
I need electric Onroad xxxssportracer R/C Items: Wanted to Buy 5 05-20-2003 04:00 PM
