Go Back   R/C Tech Forums > General Forums > Oval, Larger Scales and More
Like Tree1Likes
Old 07-09-2012, 05:24 PM   #886
Originally Posted by SuperEk4 View Post
pm snr he can do it for you.my mrx2 was done by him
Thanks! Just did!
Robert
MCD Rally X4 27.2 full mod, Nutech Beetle 30.5 full mod, Tamiya Hilux, RC10T, RC10
wyattroa is offline   Reply With Quote
Old 07-09-2012, 10:37 PM   #887
SuperEk4's Avatar
Trader Rating: 32 (100%+)
Originally Posted by wyattroa View Post
Thanks! Just did!
Robert
no problem.he make nice carbon stuffs.if u need gear or motor mount I hv a guy in Singapore who custom make them. my mrx2 is currently under overhaul by him n some drilling of holes.
Hobbywing-Acorn Racing-ManiaRC-UpgradeRC-Hong nor-Rc monster-Blackbeard-Rc-MoosDesign-SweepRacing-Boca bearings-Tresrey USA-Velociti raceware-Tekno Rc-Team J-JPL Models-SNR Graphite (RETIRED)
SuperEk4 is offline   Reply With Quote
Old 07-10-2012, 02:11 PM   #888
I don't need those parts. I got the serpent 966e so I came with those bits. But, I am not a fan of having to take the top plate off each time to mount the batteries and not being able to have larger batteries. This is the reason I would rather be able to mount them on the side and mount my electronics down on the chassis so I can have longer run times with the bigger batteries since I will be parking lot racing with buddies.
Robert
Old 07-10-2012, 02:44 PM   #889
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Robert
all i did was make a new top tray for mine. using all the same stuff as the 966E.
first off used shorty packs, had them nice and central resting at the back next to the rear radio tray support. but then wanted bigger capacity, so made it wider then to house 2 x normal 2S touring packs. i tried batts hanging off the side, its not an ideal situation. still enough room to mount electronics by having your batteries mounted at the back just infront of the radio tray support. makes for a better handling car also.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 07-11-2012, 05:41 AM   #890
strodedawg's Avatar
Trader Rating: 47 (100%+)
just picked up a mint mugen mrx4, can anyone point me in the direction to start the conversion. will run tekin rx8 and a 1750kv on 6s. any tips on starting gearing or anything else for that matter
thanks in advance
Team Whiteknuckle-JM
TLR 5B-e 10s
TLR L8ight-e 3.0 3s
TLR/Hitec/MGM/Hobbystar/GRP/RcMadness/Dynamite/Grafil/Triton rc/Bartolone Racing/Team Fast Eddy/Horizon Hobby/Puretech/Poseidon RC/Valuehobby/Punched RC/RC monster
strodedawg is offline   Reply With Quote
Old 07-12-2012, 03:54 PM   #891
SNR Graphite's Avatar
www.snrgraphite.com
SNR Graphite is offline   Reply With Quote
Old 07-12-2012, 04:08 PM   #892
SuperEk4's Avatar
nice
Old 07-18-2012, 06:31 AM   #893
SuperEk4's Avatar
what oil u guys put in the shocks? is it the same as gp? I m using 6s so its heavy.
Old 07-19-2012, 05:41 PM   #894
SuperEk4's Avatar
here's my mrx2 mod by SNR n restored by FT its almost ready except the shell n some soldering.
6s on 2000kv hobby wing system.motor mount n pinions by rc monster
Will there ever be a 1/8th scale Electric onroad car-20120720_080645.jpg   Will there ever be a 1/8th scale Electric onroad car-20120720_080716.jpg
Old 07-19-2012, 10:37 PM   #895
tjompa's Avatar
Here is a pic of my serpent 966 converted with a new top deck and batterybraces.
For sale with lots of nip parts if someone are interested. Have drove it for an hour only.
tjompa is offline   Reply With Quote
Old 07-19-2012, 10:40 PM   #896
tjompa's Avatar
How many of you guys has fried your ESCīs? i cant seem to ge this working on 6S and 2100kv. have burned One RX8, One Nosram falcon 8 and also one castle monster max with the 2200kv motor. i guess there is a little bit too high ampdraw.
http://www.youtube.com/watch?v=dlzG2kvH73Y
http://www.youtube.com/watch?v=QAoIayRrugI
Old 07-19-2012, 11:07 PM   #897
SuperEk4's Avatar
what is your gearing?
Old 07-19-2012, 11:10 PM   #898
SuperEk4's Avatar
is your direct drive or with slip?
Old 07-20-2012, 01:32 AM   #899
M7H
M7H's Avatar
I did.
But if it was the ESC or the motor, which in return fried the ESC, I will never know.
After the ESC went, I replaced it for a new one, and it immediately broke after switching it on. Turned out to be a damaged sensor board in the motor.
After switching from 6S lipo to 4S, I never had a problem like that again, other problems occure then
As you can see in your first movie in where you drive together with some nitro 8th scale cars, you can see the big disadvantage of driving 6S lipo, mounted next to the car, it handles like crap. The weight is around 500grams more, and hanging on both sides of the car, giving the car to much roll....
My 4S 966e handles almost like his nitro powered bigger brother (I still believe nitro powered is the bigger brother )
But the problem with 4S lipo, is runtime. I have not yet been able to go flat out and reach 5 minutes.
Stories I read here about 8 minutes runtime, might be true on a small track, bur running at the MACH track, a real 8th scale track, like we have a lot in Europe, is a real challenge, atleast, if you also want to have some decent topspeed.....
Serpent
M7H is offline   Reply With Quote
Old 07-20-2012, 02:21 AM   #900
tjompa's Avatar
Thanks for the replies guys.
I didnt feel that my car handled like crap, i was not very used to driving it at that point, when i managed to put the car in correct apex i had almost the same laptime as the nitro guys. if you look at the laps approx 1.50 in the movie i started to get hang of it.
I guess gearing was to high and i have no slipper, but i was told to get two 5S packs and a 1000kv motor to be on the right side with the electronics. weel maybe i will build this one as a speedcar.
I guess 4S is not an option, i want to go fast so next year i will build a 1/10 235mm pan car instead.
WTT Nitro onroad 4 electric onroad rswartz R/C Items: Wanted to Buy 0 02-16-2008 05:22 AM
WTT: 1/10th scale electric offroad for onroad... M2_Driver R/C Items: For Sale/Trade 7 10-22-2007 06:48 AM
Electric heli and 1/5 scale onroad F/S... Nitrobuzzard R/C Items: For Sale/Trade 3 08-18-2007 07:41 PM
1/8 electric onroad?? Saber186 Electric On-Road 2 04-22-2006 10:25 AM
I need electric Onroad xxxssportracer R/C Items: Wanted to Buy 5 05-20-2003 04:00 PM
