Go Back   R/C Tech Forums > General Forums > Oval, Larger Scales and More
Like Tree1Likes
Old 05-10-2010, 01:53 PM   #571
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Originally Posted by bvalistic View Post
just would like to share my project ...
test run will be at greater la track this weekend
Saw this car last Sat. It was very fast out of the corners with a lot of punch. However, it was short on gearing for the straight. Needs a 2nd gear. If Tekin can produce software for their 1/8th set up similar to the v203 software on the RS, this car would be a rocket.
Looking at it much closer shows that the top plate and side pods are made out of spring steel so its quite durable. Only problem was the batter mounting using tape was very slow. If there can be a system that allows the battery to be pre-mounted to an adaptor that plugs in and plugs out of the chassis then quick battery changes can be possible. Perhaps someone can perfect that.
YR4Dude is offline   Reply With Quote
Old 05-10-2010, 01:58 PM   #572
East Bay Pete's Avatar
I agree on the Turbo Timing / Timing Boost feature for the RX8!! Email Ty or Jim at Tekin and suggest (request?) this be put on the RX8 (assuming the hardware can accomodate the software)
Losi 8ight 2.0 Tekin 2050 Combo 4S
Ofna Hyper10 SC Mamba Max Pro / Novak 5.5 2S
Kyosho eEvolva M3 Tekin T8 / Tekin RX8 6S--Track Car
Kyosho eEvolva 05 Tekin T8 / Tekin RX8 S6--Track Car#2
Kyosho eEvolva 05 Castle Creations 2650 Combo 6S--Drag Race Car
East Bay Pete is offline   Reply With Quote
Old 05-10-2010, 02:02 PM   #573
bvalistic's Avatar
Trader Rating: 31 (100%+)
thanks for the input yr4dude! well i just ordered my 20t and 21t pinion...i ran the box stock 46t spur and 17t pinion and it's just topping off at the middle of our straight away...the car works great, it is balanced and turns really quick on chicane...i just copied exactly the same set-up as my nitro car and it works...temp wise after running 4 mins is 117 degrees...way to much room to gear up...i will be running this again next weekend and will do some videos...
bvalistic is offline   Reply With Quote
Old 05-10-2010, 02:10 PM   #574
bvalistic's Avatar
Default turbo
i think just by gearing up , it will cure the top end...but turbo timing / timing boost will be a great add-on feature...
Old 05-10-2010, 02:15 PM   #575
F1fletch's Avatar
Originally Posted by Norman2 View Post
Hi, I am attaching photos of the Kyosho Interno GT2 which Fine Design
converts to BL electric. From what I understand and depending on which
motor, Neu, etc and lipos it is pretty fast. Just for info. Regards
Norman2
That looks nice but I actually like the Kyosho conversion better I think.
F1fletch is offline   Reply With Quote
Old 05-10-2010, 02:18 PM   #576
Hey bvalistic...was 4 minutes the total run time before the batteries were out? If not, what's the total run time? Remind me...4S and what mAh?
Old 05-10-2010, 02:53 PM   #577
F1fletch's Avatar
These conversions look quite nice! Has anyone actually ran a 966e which is available now? This would be a fun class no doubt!
http://www.youtube.com/watch?v=p4WZA1FbYho
http://www.youtube.com/watch?v=H88kGIj9IUA&NR=1
Old 05-10-2010, 02:57 PM   #578
bvalistic's Avatar
Default run time
no, and sorry for the confusion...i just stop testing the stock set-up at 4 minutes...i was testing at full capacity while i was in the infield section and bliping the throtle while i was at the straight...i will be doing the complete testing next week and give you guys an update..my batteries are all 5000mah
Old 05-10-2010, 03:12 PM   #579
KostaG's Avatar
Trader Rating: 48 (100%+)
Why use spring steel instead graphite plate? Just curious.
Thanks.
Current Cars:
- Schumacher SX3 & Cougar SV
- Mugen MRX5 WC, Serpent 966e (4s)& Motonica P81e (6s)
Collector/Vintage Cars:
-Serpent F180 (2x), Serpent Veteq, Losi Jrx2, Tamiya Avante & Associated RC10
KostaG is offline   Reply With Quote
Old 05-10-2010, 08:41 PM   #580
reemo_2001's Avatar
Default ...
Wow I can't wait to get mine in the mail this week and order up the E-conversion. Looks good Don Keep us posted....
reemo_2001 is offline   Reply With Quote
Old 05-10-2010, 09:18 PM   #581
YR4Dude's Avatar
Thanks.
If you look at how the battery plate is mounted, if that were graphite plate, it would easily snap upon an kind of impact. The fact that it is spring steel would result in the battery pods bouncing back instead of getting all bent resulting in the battery packs dragging and affecting handling resulting from a side impact.
Old 05-10-2010, 10:45 PM   #582
What happened to the Empire rc conversion for the Kyosho Evolva?
williamw is offline   Reply With Quote
Old 05-11-2010, 12:36 AM   #583
Hey guys, I'm pretty close to working out availability for the pieces needed to convert the Kyosho Evolva or M3. Actually, the car parts are all designed, I'm just waiting on feedback from my battery supplier since this is a custom-sized, custom-made pack.
If you're interested in buying the pieces, let me know. Obviously, the more interest I have, the cheaper I can get the pieces manufactured.
Old 05-11-2010, 06:13 AM   #584
MAD916's Avatar
Just got our 2650 mh 5S packs yesterday so our Timezone E-mugen will hit the track again this sunday....
this is a shot from last year with 4s packs and a speed pasion speedo.... which by the way did not work.
Will there ever be a 1/8th scale Electric onroad car-photo-1.jpg
Timezone Raceway Park " on-road outdoor european style road course.
Timezone II 60'x100' indoor carpet track. Host of the ROAR 2011 Carpet Nat's.
Timezonehobbies.com your new source for online RC products.
MAD916 is offline   Reply With Quote
Old 05-11-2010, 09:24 AM   #585
YR4Dude's Avatar
That looks like a clean setup. How easy are the battery changes?
WTT Nitro onroad 4 electric onroad rswartz R/C Items: Wanted to Buy 0 02-16-2008 05:22 AM
WTT: 1/10th scale electric offroad for onroad... M2_Driver R/C Items: For Sale/Trade 7 10-22-2007 06:48 AM
Electric heli and 1/5 scale onroad F/S... Nitrobuzzard R/C Items: For Sale/Trade 3 08-18-2007 07:41 PM
1/8 electric onroad?? Saber186 Electric On-Road 2 04-22-2006 10:25 AM
I need electric Onroad xxxssportracer R/C Items: Wanted to Buy 5 05-20-2003 04:00 PM
