Go Back   R/C Tech Forums > General Forums > Oval, Larger Scales and More
Like Tree1Likes
Old 07-14-2009, 08:56 AM   #406
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Originally Posted by East Bay Pete View Post
Here is my 2nd brushless conversion of a Kyosho Evolva 2005 that I just completed. This time, instead of the 2 speed setup, I went for the single speed direct drive. The hard case, 4S battery pack (I call it the "Tower of POWER"!) sits centered on the chassis between the front pulley and the rear chassis brace. Swapping the battery is a "drop in" proceedure (without the body on, of course) and takes no time at all. Notice that I am now using a large capacitor with the Mamba Monster to help offset voltage drop when the motor pulls high amps (180+!). It also helps smooth out more of any ripple current coming off the packs. I'm running the Castle Neu 2650 kv along with a Novak 40mm fan on the motor. The custom carbon fiber top plate completely surrounds the battery securing it in place and offers additional protection in addition to the hard pack.
Gearing as pictured was 22/48 with plenty of top end speed! For my first setup, I ran 18/48 for a total runtime of a bit over 7 minutes with still a bit left in the packs. The packs are 6000 mAh. I didn't time the run with the 22/48 gearing. With a bit taller gearing top speed is probably in the range of 65-70 mph, however I don't know what temps and run time this gearing would yield.
While this car won't ever be as fast as my 6S 2 speed setup, it definitely handles better and is a simpler setup. One thing I noticed after logging data with the 2 speed car is that every time the car was shifting on the track, there was an amp spike and corresponding decrease of RPM...resulting in a bit of delay on the back straight. This was never an issue with doing all out speed runs, but on the track it was a different story. I finally had to have it shift almost immediately into 2nd to avoid the amp spikes upon shifting. This improved the performance out of the packs.
I like the battery set up.. Does it fit under the body ?
Cleaver to use the saddle packs like that .
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 07-14-2009, 09:11 AM   #407
Solara's Avatar
Trader Rating: 16 (100%+)
Very nice work...I too sized the saddle packs before on my Serpent and it was a very good power setup for 1/8th conversion except 1 thing...it won't fit with the LOLA type body unless punching a hugh opening like for the fuel tank....
One thing I also noticed...exactly like you said, I have seen 1/8th conversion (buggy type like Dm1 spec) when using 2-speed...it does DELAY big time before the shifting...I am not sure that has to do with the SHIFT POINT from the 2-speed. For my understanding, gear box is only "Shifted" or "Not shifted". From what I can see, using electric motor with 2-speed, it has a delay due to the torque kicking back to the motor plus the AMP SPIKE toward the motor and cause the motor to DELAY....it was like, me driving a manuel transmission FERRARI the 1st time (Never did, just an example) and try to shift from 1st to 2nd....
Not sure there is a cure or need for the 2-speed gear box when using brushless motor UNLESS it is for the speed run....but I know the SCHUMACHER team did that rocket RC car and broke the world fastest record, that car does not have a 2-speed or 3-speed gear box...only single spur (or I should say a pinion cause the pinion and spur look like the same size...LOL)
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 07-14-2009, 09:38 AM   #408
East Bay Pete's Avatar
Thanks for the compliments! The car really is a lot of fun because you don't have to worry about starting, tuning, fuel, etc. Just walk up to the pit lane, drop your own car, walk up to the driver's stand and go!
I'm using the Lamberto Collari MLC 908 body and the packs push the body up about 1 mm...you can barely notice. I would like to try the Protoform P909 next...It should be about the same in this part of the body...what do you think?
I agree...there is no "buffer" between 1st and 2nd so there's an instant load on the motor causing the amp spike leading to a voltage drop leading to a loss of RPM's (about 3,000-4,000) and so on. Those spikes really take a toll on the battery packs...30+C minimum required!
Losi 8ight 2.0 Tekin 2050 Combo 4S
Ofna Hyper10 SC Mamba Max Pro / Novak 5.5 2S
Kyosho eEvolva M3 Tekin T8 / Tekin RX8 6S--Track Car
Kyosho eEvolva 05 Tekin T8 / Tekin RX8 S6--Track Car#2
Kyosho eEvolva 05 Castle Creations 2650 Combo 6S--Drag Race Car
East Bay Pete is offline   Reply With Quote
Old 07-14-2009, 10:28 AM   #409
Solara's Avatar
Next time at the track, see you can record some lap time and run time by simply using the single speed....I just don't see the advantage in this BL conversion application as long as your pinion and spur is the same or bigger then when you were using the 2-speed application. Good luck.
Old 07-14-2009, 11:25 AM   #410
Well first of all I don't believe a 2 speed is necessary . The electric motor does not need the torque advantage the trans provides. The extra weight alone should be enough to just omit it. Let alone the spikes to the cells you may be experiencing. As far as the body, can you mill out a pocket on the chassis a mill lower ?
Old 08-12-2009, 04:22 AM   #411
js058515's Avatar
Default Thanks East Bay Pete
Thanks East Bay Pete for directing me to this thread. There is definitely some great minds at work here. Almost makes me want to drop some money on a Evolva......gotta be patient while you smart people figure out a great setup for me. Very nice work so far guys.
js058515 is offline   Reply With Quote
Old 08-16-2009, 02:00 PM   #412
js058515's Avatar
Originally Posted by Oblivionixx View Post
Just make a post to keep this thread in the first page lol....
any new work can be shown?
can wait to see the M3 conversion
I am doing what he did......
Old 08-16-2009, 06:21 PM   #413
Thumbs up
Some of your conversions are amazing to say the least.
We understand that companies that make our products are just that....a business. So there is always super secret squirrel stuff going on that we can not really talk about. We can tell you there are two companies working on e versions of their nitro cars.....both are works of art. One not to different then what we have seen on here. IF, again IF we get permission we are going to try and post some pics on here and on facebook under rctvlive. I think 1/8th scale on road brushless would open the door for many that do not like tuning nitro engines of this size. Time will tell. Jeff
RCTVLIVE the finest in radio control television. Now seen on the USTV network
You can follow up to the minute news and information on Facebook and Twitter under RCTVLIVE! www.rctvlive.comNOW ON AOITV (Adventures Network) and AOITV.COM as well!!!!
Jeff's RC Studio on Facebook and www.jeffsrcstudio.com
Spec175GT
RCTVLIVE is offline   Reply With Quote
Old 08-16-2009, 08:01 PM   #414
+1
Old 08-22-2009, 02:33 PM   #415
Default Kyosho Evolva 2005
http://www.amainhobbies.com/product_...Racing-Car-Kit
$309.99 (current special price, 5 available)
$284.99 (after coupon code DPPAN925)
plus S&H and Tax if applicable. And don't forget a free T-shirt! (I have no relationship with A Main Hobbies other than a happy customer)
8ight 2.0 RTR and RR Part Diffs> http://www.rctech.net/forum/6212031-post1.html
Tired Racer is offline   Reply With Quote
Old 08-22-2009, 05:18 PM   #416
What ? This old thing ?
I have 2 2001 fantom kits one used and the other new.
waiting to be converted. $200 +ship for both ..parts too!
Old 08-22-2009, 10:22 PM   #417
Cool! Did your parents buy it for you?
Old 08-22-2009, 11:39 PM   #418
js058515's Avatar
That's a great price even for an older version. The price is right for a newbie to get into 8th scale "Formula One" racing regardless if it's nitro or electric. Good find!
Old 08-23-2009, 01:24 AM   #419
Umm.. no.
Old 08-23-2009, 08:06 AM   #420
tjompa's Avatar
Originally Posted by js058515 View Post
That's a great price even for an older version. The price is right for a newbie to get into 8th scale pan car racing regardless if it's nitro or electric. Good find!
Never call a 1/8 track chassi a pan car again
Sorry mate.
tjompa is offline   Reply With Quote
WTT Nitro onroad 4 electric onroad rswartz R/C Items: Wanted to Buy 0 02-16-2008 05:22 AM
WTT: 1/10th scale electric offroad for onroad... M2_Driver R/C Items: For Sale/Trade 7 10-22-2007 06:48 AM
Electric heli and 1/5 scale onroad F/S... Nitrobuzzard R/C Items: For Sale/Trade 3 08-18-2007 07:41 PM
1/8 electric onroad?? Saber186 Electric On-Road 2 04-22-2006 10:25 AM
I need electric Onroad xxxssportracer R/C Items: Wanted to Buy 5 05-20-2003 04:00 PM
