Go Back   R/C Tech Forums > General Forums > Oval, Larger Scales and More
Like Tree1Likes
Old 05-20-2009, 02:03 PM   #316
YoDog's Avatar
Trader Rating: 26 (100%+)
Originally Posted by DLS II View Post
Quick-change packs could definitely be done. Remember the 1/10 superspeedway stock cars? A pit man could change a 6 cell nicad pack in 3 seconds! If need be, there is no reason it couldn't be done with 4s lipo packs. Don
I have already started on a quick change solution for my chassis. I will most likely incorporate it in the next revision of the chassis plate.
The user can buy extra battery trays and have packs mounted and ready to use. There will be no plugs to fiddle with and no screws to remove.
Should be a 3-5 second change!
YoDog is offline   Reply With Quote
Old 05-20-2009, 02:15 PM   #317
I hope this is all being done on your Evolva?
DLS II is offline   Reply With Quote
Old 05-20-2009, 02:29 PM   #318
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by John St.Amant View Post
So why couldn't some new form of car with Li-Po's in it have an apparatus for quick change battery packs. It might be a bit costly for all the cells but it could be done. Never say never and always always always keep an open mind.
Just don't get me wrong....everything you mentioned I have seen and heard of, but for 1/8th nitro on road, I just don't see it and probably will not happen that way. If changing lipo is the only thing need to be figure out...you will see IFMAR 190mm on road a 1 hour main instead of triple A-main.
For me...I just want to see this conversion can run against nitro car for good 5-10 minutes...but to make it run an 1 hour main, I just don't see that is necessary, even with the lipo change, thats my opinion.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 05-20-2009, 03:17 PM   #319
phatmonk's Avatar
Default Brushless !/8 onroad Car
This started out as a GTP but now its more custom parts than original.This is a blast to drive.It has a Neu 1515/.5Y 4400KV on 3S with a Mamba Monster.I was gonna convert a Serpent but a GTP chassis was cheap.Either way I ended up spending alot finishing the car.I did put a D-Box on it and it handles great.Try it i realy like it.I have owned a PRP XR8 and it was hard to drive so i went this route.
Will there ever be a 1/8th scale Electric onroad car-dsc05144.jpg   Will there ever be a 1/8th scale Electric onroad car-dsc05143.jpg   Will there ever be a 1/8th scale Electric onroad car-dsc05138.jpg   Will there ever be a 1/8th scale Electric onroad car-dsc05139.jpg
E-SC8 MMM Neu/Castle 1717
RC8BE SC MMM Tekno Neu 1515
Slash 4x4 MMM Neu 1512
phatmonk is offline   Reply With Quote
Old 05-20-2009, 04:55 PM   #320
wwoodruff
Guest
Posts: n/a
That looks great, who cut the chassis for you?
Old 05-20-2009, 06:13 PM   #321
phatmonk's Avatar
I cut it myself with a 21tpi metalcutting jigsaw blade on my Bosch jigsaw and dremmal with a plunge router bit.The SSG Carbon was pricy though and hard to find.If you cut slowly it wont burn or seperate it.I have run into a wall with RC and wanted to start creating my own cars.
Old 05-20-2009, 08:45 PM   #322
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Looks good but thats a double conversion in my book.
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 05-20-2009, 11:25 PM   #323
YoDog's Avatar
Yupp,
I already use a bottom loading tray so I will make a custom tray and change the chassis opening a little bit.
Old 05-20-2009, 11:38 PM   #324
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
What kind of speeds are you reaching with this car? How much did you end up spending to convert?
IIGQ4U is offline   Reply With Quote
Old 05-21-2009, 01:44 PM   #325
phatmonk's Avatar
I spent 120.00 for the 4mm carbonfiber.Thats alot in my book.ESC 135.00,Neu 205.00,Motor mount 35.00,Battery on ebay 175.00.Kinda got out of hand.Then the custom painted body 120.00.Havent clocked its speed yet but ya cant run it full out because ya run out of space.The D-box is fun though it drifts great with the foam tires.And foam tires are a must because the rubber stock tires balloon and rub the body.The CF Sheet measured 4x200x450mm so there was plenty of extra to make the MMM mount/rear chassis brace.The chassis is symetrical also.
Old 05-21-2009, 03:30 PM   #326
Footage of my 1/8th onroad conversion.
***CLICK***
CountryHick is offline   Reply With Quote
Old 06-01-2009, 03:48 PM   #327
any news or pics of 1/8 conversion?
Oblivionixx is offline   Reply With Quote
Old 06-01-2009, 06:25 PM   #328
Here are some items that you fellow adventurers may like.
eM3* Motor mounts transmission adapters. Give it a swing. Brew your own.
You can join the leading edge of 1/8th Electric.
The Empire eM3 will be running at 301 this weekend. Stop by our pits and check it out
* Designed for the Kyosho M3 only. We, also, strongly recommend The Castle MMM Speed controller and 2650KV motor.
Will there ever be a 1/8th scale Electric onroad car-m3e-parts-001.jpg   Will there ever be a 1/8th scale Electric onroad car-m3e-parts-003.jpg
Rich Browne is offline   Reply With Quote
Old 06-02-2009, 12:24 AM   #329
Just feel curious is there gonna be some conversion kits for any 1/10 nitro car like V-one RRR lol?
Old 06-02-2009, 02:48 AM   #330
rather amusing question - like, are there plans for gas conversion for a Tamiya (just curious) lol.
WTT Nitro onroad 4 electric onroad rswartz R/C Items: Wanted to Buy 0 02-16-2008 05:22 AM
WTT: 1/10th scale electric offroad for onroad... M2_Driver R/C Items: For Sale/Trade 7 10-22-2007 06:48 AM
Electric heli and 1/5 scale onroad F/S... Nitrobuzzard R/C Items: For Sale/Trade 3 08-18-2007 07:41 PM
1/8 electric onroad?? Saber186 Electric On-Road 2 04-22-2006 10:25 AM
I need electric Onroad xxxssportracer R/C Items: Wanted to Buy 5 05-20-2003 04:00 PM
