Go Back   R/C Tech Forums > General Forums > Oval, Larger Scales and More
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 02-27-2007, 12:02 AM   #1
Trader Rating: 2 (80%+)
Default L4 Oval Carpet How to make faster
Ok I am racing spec class on a carpet oval track 4 cell 1600mAh battery as required and a trinity spec motor as required. It sure seems there are others racing the same car same battery and motor that are faster turning 5-6 more laps. What can I tweak to gain speed and remain legal. Can a spec motor be optimized? If so how. Last race I took 3rd over all but the other 2 guy constantly stomp everyone else inlaps and times..
Any helps appreciated
gunlocators is offline   Reply With Quote
Old 02-27-2007, 05:53 PM   #2
It's probably not the motor, or the battery. First you have to get your chassis set up and balanced for maximum efficiency, then the right rollout. Everything has to be clean and moving freely. When you get to that point - then you can worry about the motor and battery.
slots is offline   Reply With Quote
Old 02-28-2007, 10:13 AM   #3
RCMits's Avatar
check our their cars. i found oval guys are pretty cool in that respect.
are you scrubbin any speed in the corners? are you guys running the same tires (size and colors)? are you running similar or same rollouts as the "fast" guys? are you driving their "lines" around the track?
5-6 laps is alot, which means your probably getting lapped yes? with no one on the track, how is your laptime? is it comparable?
hope that gives you a start..
RCMits is offline   Reply With Quote
Old 02-28-2007, 06:31 PM   #4
I am scrubbing the corners. I am running greens on back and blue rt front not sure on left its 3/4 black foam then 1/4 grey could of been about anything I guess I got the car set this way.
Old 02-28-2007, 06:41 PM   #5
I have on my car which is setup how i bought it used
springs side gold lf blue rt black center
Tires rear green blue rt front unknown left front its 3/4 black foam 1/4 grey foam its missing the sticker
On my gears I am running a 120 / 39
Originally Posted by hill jack
I hope you dont mind me pming you. Alot of guys I race with visit this site if you know what I mean. This is what I run setup wise.
Sidesprings: assoc blue
Center spring: assoc silver
I just bought a new spec motor and it was trued at LHS / Race track within spec so not to be disqualified.
I bought a Airtronincs M11 so I took out a lot of over steer so that help a lot.
side shock oil: 20wt
Center shock oil: 50wt
tires: (specs) on the rears trinity pinks, lf trinity blue, rf BSR silver
front springs: lf red rf green
I hope this helps any more questions feel free to ask
Old 02-28-2007, 08:44 PM   #6
RCMits's Avatar
see what the fast guys at your track are running. ask for help, most oval racers are VERY helpful.
im new myself (to oval), and i ask MANY questions, and everyone helps at the track =)
Old 03-23-2007, 06:41 AM   #7
Send a message via Yahoo to viperbill1963
Red face go fast turn left ...repeat
what the track size ,what size are your tires ,is the track big and sweeping or small and tight in the cornors ,do you have to let off the gas to get thru the cornors ,do you run a bias set up on the tires in side tires smaller by .25 inch, i would ask a fellow racer and see if they can help you out as far as setup starting point and motor help ,
viperbill1963 is offline   Reply With Quote
Forum Jump
How do you make a Electric RC CAR go faster ivoo Electric On-Road 9 11-08-2007 06:02 AM
How to make your RC cars go Faster kamikazi Australian Racing 19 07-11-2007 05:18 AM
Something to make Gas Cars go faster nudge2325 Australian Racing 5 01-08-2006 04:54 AM
How to make RC10T3 RTR Faster? jlarnai Rookie Zone 5 09-12-2004 04:00 PM
make my P2K2 Pro...faster unknown Electric On-Road 17 02-09-2003 11:19 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
