Baja 5B Problem
Hello,
Ive been having a problem with my baja's engine. I cant figure this one out. The engine simply isnt getting any fuel. I tookt he entire carb apart, cleaned it, blew it out, etc. no noticeable marks on the piston possibly from dirt, no loss of compression, etc. and the engine is still making vacuum at the intake manifold. and the spark plug is making spark but fuel does not get inside the engine, and it doesnt even make an attempt at starting.
It was running yesterday, but what would happen is it would start up relatively normally, it took a little extra then usual to start but not much worse. it would run kind of okay, but its low end bog was much worse, and the idle was really low. tuning it wasnt helping. then it eventually stalled after it was run for a few minutes. didnt start again that day. I tried running it today, did the usual start up routine, full choke, pull it till it sputters, it sputtered. then that was it. didnt even make a remote attempt after that. thats when i pulled the carb apart etc.
im puzzled. does anyone have any ideas or have had this kind of problem? im calling HPI tomarrow but if i could get a possible solution before then, i would appreciate it.
