Originally Posted by Tony Vega
You missed a great race this past weekend. Next time come on out. Plenty of racers would have loaned you a pack.
Well, what happened is I went to go test everything out (for the first time ever, the day before the race, late at night
) and the transmitter wheel wouldn't re-center (NOOOOOO!). So I hope for the best and figure that the clock spring just broke. I commence to take the transmitter apart (JR R-1) and one of the upper allens on the drop down base wouldn't come out! The whole front assembly came off of the transmitter but it wouldn't split apart because of one allen screw! One of the nubs had broken flush with the steering case so it would just spin with the screw. So after a couple of hours of blood, sweat, stress breaks and berrating at the control I manage to remove the screw. The spring was broken (off course
) and suprise suprise, the potentiometer is loose(
). I glue the potentiometer back in place, make the spring work, put humpty back together, go to sleep close to 6am and wake up at 11ish to find out that it was all a nightmare. The end
