BOCA Bearings Help
BOCA Bearings Help
I bought a set of BOCA Bearings for my 321P for emergency purposes.
I got this set on their recommendation-
http://www.bocabearings.com/main1.as...4&n=*ENK-148HP
I'd ask BOCA, but the recent hurricanes in FL appear to have shut them down for the time being. My question(s) are:
1). the front bearing has two seals. Which one goes on the outside- green or black? I'm guessing the black seal.
2). which side of the rear bearing faces the backplate? the caged or uncaged side? the stock bearing currently in the engine has the cage facing away from the backplate. I assume this is correct?
Thanks.
Thanks.
>>> green or black is all ok. You can remove one seal.
>>> ball's retainer face to the crankcase so it won't fall off.
