Old 10-07-2005, 05:23 PM   #1
Burnz27's Avatar
Send a message via MSN to Burnz27 Send a message via Yahoo to Burnz27
Cold weather & Nitro Engines?
Hey guys, I'm getting into nitro RC and I was wondering how these engines do in cold weather? As in, is it recommended, or do you guys put the cars and trucks away for the winter. Other than the moisture involved with snow, do these things run in the cold.
Winter is fast approaching in Illinois and I don't want to have to look at the thing on the shelf all winter and wonder if I should just wait til spring.
Burnz27 is offline   Reply With Quote
Old 10-07-2005, 06:48 PM   #2
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Water is really your only enemy and even then I know people do even run in the ran. Even some races are run in the rain.
I would just be sure to bag your electronics , aka make sure no rain gets to them. Little baloons and other things work good for stopping that.
Afterwards I would be sure to blast it dry with a compressor and apply liberal amounts of wd-40 to all metal parts.
Artificial-I is offline   Reply With Quote
Old 10-07-2005, 06:52 PM   #3
Aphinity's Avatar
Send a message via ICQ to Aphinity Send a message via AIM to Aphinity Send a message via Yahoo to Aphinity Send a message via Skype™ to Aphinity
Cold weather means cooler temperatures, more oxygen in the air (unless it's below or close to freezing), and generally good attmosphere for the engines to run.
While I don't regularly run in cold weather, if you are running in freezing conditions, you might have to run a hotter glowplug to make the engine run properly.
I'd say go for it. I don't see a reason to hold back! Tower hobbies sells front wheel ski-conversion kits for the RC-10GT, so there has to be a reason for it!
Aphinity is offline   Reply With Quote
Old 10-07-2005, 06:53 PM   #4
Hesky's Avatar
good question, from my experience nitro engines can be a tad fiddly to start and get up to running temp in cold weather but if you run a hot or even an ultra hot plug depending on conditions you should have no problems keeping a stable tune, cold air is denser air so thats a slight + i guess.
actual extreme weather conditions like snow is another matter, I would keep your car tucked away until that sort of weather blows over.
edit: oops, pretty much repeated what Aphinity said, we're just to quick to respond ah well
Hesky is offline   Reply With Quote
Best gripping tires for tc5, cold weather jms04081974 Electric On-Road 9 01-07-2008 04:07 PM
cold weather starting esdjc Onroad Nitro Engine Zone 5 09-17-2007 03:48 PM
Cold weather & Nitros Oasis Monster Trucks 13 12-17-2004 06:06 AM
What temperature do you run in cold weather(winter)? dino.tw Nitro On-Road 18 12-09-2003 02:35 PM
Cold weather glitching? fatdoggy Electric On-Road 4 10-19-2003 05:10 PM
SEO by vBSEO 3.5.0
