Old 12-13-2014, 11:35 PM   #1
Bundy_Bear's Avatar
Default Engine Temperature
Howdy,
Just wondering if it is normal for engine temperature to change over a longer run? Last night was checking in the warm up and then again when run had finished. During 5 minute qualifiers no real change between the two readings. Over the longer 15 minute final the second reading at the end of the race was 25 degrees higher then the warm up.
Thanks in advance
Andrew
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 12-14-2014, 12:27 AM   #2
Roelof's Avatar
Send a message via ICQ to Roelof
It takes a while that the engine is really warmed up. I have a clear telemetry readout:
https://www.youtube.com/watch?v=cwkVENYaK-k
On the right in the graph and right under is the temperature readout. The engine was pre-heated to almost 80 degrees C as you can see on the digital meter. From running the 1st lap (1:20 Youtube time) it took 2 minutes before the temperature goes up beyond the 80 degrees C. At 4:20 I do a practise start where you can see a huge raise of the temperature when the car is standing still. That is where the cooling stops and all the heat will concentrate in the engine.
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 12-14-2014, 12:45 AM   #3
Bundy_Bear's Avatar
Thanks Roelof, When i say warm up the car had been running for a few minutes at full speed on track and I would check it as i refueled the car before the run started.
MissMooRC Racing
Old 12-14-2014, 03:46 AM   #4
blis's Avatar
Andrew could also be lower fuel pressure as the tank empties, drop in air temp, or a dreaded air leak.
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 12-14-2014, 04:05 PM   #5
Anf
What telemetry is that and is it possible to add exhaust gas temperature readings?
Anf is offline   Reply With Quote
Old 12-14-2014, 04:08 PM   #6
Bundy_Bear's Avatar
Harry,
Thank you, will check for air leaks. If it was fuel pressure should it be the same at the end of a 5 minute run as the fuel load comes down?
Andrew
MissMooRC Racing
Old 12-15-2014, 02:06 AM   #7
Roelof's Avatar
That one is based on an old datalogger from www.conrad.com
You can read it all here:
New project comes alive.
With standard analogue inputs and adding formula's and I/O transfer tables for the right readout on the screen I can add any type of analogue sensor. So yes, exhaust temps are possible.
Old 12-15-2014, 02:08 AM   #8
fyrstormer's Avatar
Harry,
Andrew
The fuel pressure doesn't change as the tank empties. The exhaust is capable of supplying more than enough hot gas to pressurize the tank faster than the carburetor can suck fuel out of the tank.
fyrstormer is online now   Reply With Quote
SEO by vBSEO 3.5.0
