MAX POWER ENGINES
#316
#317
MX 21 MAX XL9 TQ
Hi
I am runing MX 21 MAX XL9 TQ with glow plug c7 25% nitro, the enigne is not running above 210f temp
and I have broken 3 glow plugs already any Idea?
thanks
thanks
#318
#320
If this motor has over a gallon on it and still the original rod, it may be time for a new rod.
If there is any pitting on the top of the piston and bottom of the head, add a shim.
#321
wow
#322
Please help
Does anyone know the factory needle settings on the xxl3 or a good place to start??? having trouble getting it to idle and run... Thanks for any tips
#323
Hey
I'd like to find out some info on this xxl3 engine. What novarossi engine is it based off of. Does it run good on a nova 2652 pipe with a 41616 header? What is the temperature range for racing. Also what's the best glowplugs to use and the #.
Thanks.
Thanks.
#324
Get the 2660. Is it much better than 2652? better mileage and similar power band.
http://www.rc-toro.com/product_info....4cbe5d0cc63668
#325
#326
Yes you guys are right there will be a new .12 from Max Power that has a new carb. Maybe it will be called the "WG10"..
Also guys the engine we ran at the pre-worlds and the Xray race was an engine Ralph pulled of the shelf from RCA. Just to prove that the Max engines we sell are the same we race.
Thanks Drew
Thanks Drew
congratulations for the win (or your participation in it). Which pipe do you usually use with XXL3? Nova 2664, Max2649, another? Have you noticed any difference in power or consumption among them?
Thanks,
Carlos
#327
hi does anyone know where i can get this part maxpower 02013xl9 for the tq xl9????????? need one urgently!!!!!
#328
#329
Thanks stefan
Thanks man,, after 4 frustrating days at the track trying to get my xxl3 running right,, it's there.. I was waaaaay off on my low speed.. The motor sounds and runs great.. Thanks again for the settings tip...
#330
which shops carries 12 max with great prices and support, besides amainhobbies.com
