Old 09-23-2005, 05:21 AM   #1
Default Differences between 3port vs 5 port, Turbo vs Non turbo
If you could explain the differences between a 3 port vs 5 port engine, and a Turbo vs Non turbo engine, I would be very grateful. I believe the Turbo in these engines are different from the Garrett Turbochargers you find in 1:1 cars.
nikkor is offline   Reply With Quote
Old 09-28-2005, 02:35 PM   #2
duneland's Avatar
3 v.s. 5 port etc. Number of ports (holes) in the sleave not counting the exhaust port.
Turbo is a widely mis-used term. In glow engines, it most often refers to the glow plug/head. Turbo is the conical variety that does not use a copper gasket.
duneland is offline   Reply With Quote
Old 09-28-2005, 05:24 PM   #3
Hesky's Avatar
lol the term turbo isnt used in the same sense here! it is actually fundamental impossible to turbo charge 2-stroke engines, rc 2-strokers use high % nitromethane, which will give you all the power you would ever need with no lag
Turbo plugs seal with the button head in such a way you are guaranteed a flush fit with the combustion chamber, which intern gives better performance. the down side with turbo type head buttons is the ability to get a good air tight seal with dirt and crap that can come between the to contacting surfaces. standard type plugs have a copper washer that help get a good seal when the surface of the head button is less than clean.
hence why on-road use turbo heads and off-road use standard heads.
pic comparing the 2 types below...
with regards to inlet port numbers some engines tend to have extra boost and transfer ports which make it possible to direct the fresh mixture into every part of cylinder forcing out spent gas, this will actually give it a better volumetric efficiency (can cram more mixture into the cylinder).
remember more ports isn't alway better! a poorly designed 5 port sleeve may be out performed by a well designed 3 port.
Hesky is offline   Reply With Quote
turbo 35 and turbo 35 gfx differences xrayflorida Radio and Electronics 1 06-04-2008 01:54 PM
NEW IN BOX CE Turbo 30 with Turbo Flex and printer Port ap714 R/C Items: For Sale/Trade 0 12-29-2005 12:54 PM
FS: NIB TOP .12 3port turbo motor, NIB RD Logic Turbo II exhaust rossiRocket R/C Items: For Sale/Trade 19 12-06-2005 09:10 AM
Turbo crank in a SX12 RE 3Port Turbo MDS Nitro On-Road 5 04-03-2003 11:33 AM
Is there competion between a Jp Modify 3 port turbo vs Rb 5 port turbo? Raytrix Nitro On-Road 8 03-13-2002 09:11 PM
SEO by vBSEO 3.5.0
