Old 07-07-2014, 02:51 PM   #1
Phil Trotta's Avatar
Default Novarossi ISON 7 port tuned .21
This is a pic of the crank on the new Novarossi ISON tuned 7port
Balanced 14 mm factory tuned crank , steel bearings, and a killer price
I saw this motor run by Paolo Morganti and Vincent Jackson at the Byron's challenge in Joliet.
The motor had killer power and excellent run time ...
PHIL TROTTA
TQ WIRE.....HOBBY HEROES.....FORDHAM HOBBIES.....360v2 RACEWAY
Phil Trotta is offline   Reply With Quote
Old 07-08-2014, 08:48 AM   #2
are they running with the stock version?
kyosho malaysia is offline   Reply With Quote
Old 07-08-2014, 06:26 PM   #3
This version is what was run
PHIL TROTTA
Old 07-09-2014, 01:50 AM   #4
have you did comparison between yr ISON with theirs
Old 07-09-2014, 03:45 AM   #5
Thumbs up
This weekend. I will be running this engine . If you meant were they running a team version.... I believe not. They ran engine in same form
PHIL TROTTA
Old 07-09-2014, 07:14 AM   #6
i'm not mean team version,they may do some mod themselves
Old 07-09-2014, 10:48 AM   #7
Got ya. I'm gonna run it in Friday and use it all weekend I'll post a heads up on Friday night
PHIL TROTTA
Old 07-09-2014, 01:05 PM   #8
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
Phil were they on par with the older Kangaroos?
Inf1nity CM Beat1 Racing
VP Powermaster
Serpent-Dan is offline   Reply With Quote
Old 07-09-2014, 02:40 PM   #9
Trader Rating: 22 (100%+)
Its basically the Kangaroo with a slightly different crank and cooling head. Same Piston/Liner/Rod/Crankcase/Carb etc as the Kangaroo. It is in all intents and purposes simply an update to the Kangaroo Sydney WC engine which has now been discontinued.
Serpent Viper 977e, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.0, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 07-09-2014, 08:59 PM   #10
Vincent did some of the fastest laps in the a main at Byron's as well as his qualifying with this engine and had excellent run time to boot
That's what led me to pick one up.
PHIL TROTTA
Old 07-10-2014, 12:20 AM   #11
Thanks Phil
VP Powermaster
Old 07-10-2014, 03:16 AM   #12
mine is on the way
Old 07-10-2014, 03:21 AM   #13
ISON with 3 needle cab,KAPPO only 2
Old 07-12-2014, 02:38 AM   #14
Ok so I ran this motor in a little ... About 3/4 gallon of fuel. Even from the first tanks you could feel this motor is a contender
We leaned motor down a little. Left it slightly rich and I can say I'm very Happy with the engine
Motor was running in the 240 temp range still slightly rich and has very good bottom end and pulls all the way through the top
Will finish running in today see how it qualifies The motor made 5:30 on a track that is not easy to make 5 min runtime. This was with the supplied 8.5 restrictor and 2015 pipe with short header
PHIL TROTTA
Old 07-13-2014, 07:24 AM   #15
240F with slightly rich setting,it may not fully running in yet.
SEO by vBSEO 3.5.0
