Old 10-11-2005, 05:16 AM   #46
macnkitty2002's Avatar
yay!!! i got it to start without a problem! i purchased new fuel, new(hotter) glow plugs, and a new glow driver. i think because i had a cold plug in the engine it wouldn't get hot enough to ignite the fuel. plus, i think the fuel itself might be a little worn out. getting a better glow driver, one that will last all day, will certainly help too. obviously i heated up the engine with a hairdryer, which helped tremendously.
RC10B4.2
macnkitty2002 is offline   Reply With Quote
Old 10-14-2005, 06:50 PM   #47
Default used crank
im looking for a halfway good crank to buy for a ws7 2 engine.
and who thinks rb engine kick butt?
and i have another ? whats the best way to lighten the aluminum
shoes?
hyper761 is offline   Reply With Quote
Old 11-22-2005, 06:31 PM   #48
Can someone please tell me where I Can find a conrod replacement and main bearing for RB engines( RB V12 and RB 1005-C)
rc racing dude is offline   Reply With Quote
Old 11-23-2005, 10:11 AM   #49
http://www.acehardwarehobbies.com
800-383-2657
http://www.ashfordhobby.com
800-380-6517
Rich Browne is offline   Reply With Quote
Old 11-23-2005, 05:32 PM   #50
Thanks, again Rich! BTW What % of nitro are you using for your RB 1005-RC and what is the head shimed at. Thanks Mike
Old 11-24-2005, 01:28 PM   #51
We run 30% White Lightning - the heads are shimmed between .023 to .027. Depends on humidity and altitude. We also use the 4 dot High Compression Nova Rossi head - I believe RB has it I don't know the P/N. Where are you running the motor?
Old 11-24-2005, 04:20 PM   #52
Rich, I live in north east Ohio, Not to far from the track in Toledo. The next race will be the winter nats, If my son decides to go, he is the one who races the 05 Evolva. We have in the past run novarossi base motors. Looking to try the RB motors this year and have better luck with this engine. You talk very highly of RB engines and you and Scott seem to have very good success with this motor.This is why I'm asking so many Questions about the Rb 1005-R/C motors and hoping to finally learn something worth while. Thanks, Mike
Old 11-24-2005, 04:28 PM   #53
Ask away - happy to help. RB's are well built, fast motors. You are making a a good choice. Feel free to eMail me at rich@empirercracing.com.
Old 11-26-2005, 05:13 PM   #54
n.e.r.d's Avatar
Default rody v12
hi guys,
i'm looking to get an Rb v12 rody.
deciding btw the 3port or 5port.
which wld give a better bottom end?
i'm guessing the 3port as a 5port = higher top-end right?
i need more punch out of corners as thr is only one long straight at my track.
thanks in advance!
n.e.r.d is offline   Reply With Quote
Old 11-26-2005, 07:49 PM   #55
Originally Posted by n.e.r.d
hi guys,
thanks in advance!
If you go with the three port, you will be legal, if that is an issue. To get the punch out of the corners, you need to get the clutch dialed-in and get the motor's low end needle tuned correctly.
Old 11-27-2005, 02:02 AM   #56
n.e.r.d's Avatar
thanks for the info rc racing dude.
for me, 3port or 5port doesn't matter. no legality issues here.
i was thinking that in general, 3port engines has better low-end and 5port ones has more top-end.
even when i looked at the rb website, the 3port rody has more torque than the 5port rody.
but i guess that the 5port will have more power overall...
Old 12-07-2005, 02:30 PM   #57
Send a message via Yahoo to hardadz
Default RB Concept Engines
You can get these through www.evolutionhobbies.com. Just send them an email at sales@evolutionhobbies.com
hardadz is offline   Reply With Quote
Old 12-15-2005, 07:23 PM   #58
Default replacement piston/sleeve in a c5 rody
i just bought a used c5 rody. i was wondering if anybody has put the replacement rody piston/sleeve in a used c5 and if the power was comparable to the original motor?
thanks.
sedanaddict is offline   Reply With Quote
Old 12-18-2005, 11:22 PM   #59
thanks.
It should be just as good as new. Just make sure the crank pin is still round & the right size. If it's not replace the crank too or you may find your engine having a midlife crisis.
GBagRacing is offline   Reply With Quote
Old 01-25-2006, 11:19 AM   #60
Default RB pipes
Any one using the .12 inline pipes from RB? How are they compared to the other pipes you have used? I'm thinking of going with the MFG recommendations for my V12 5 port & my V12 rody. Would love some feedback on this. Thanx
TM, Murnan, RB, Morgan, Nomadio, GQ, Integy, GP, Duratrax, Protoform, Cruisin, Raceday, Wolf
GRP... Engine... Thread... xlgraphicspro Offroad Nitro Engine Forum 2135 09-10-2013 08:46 AM
Palmaris engine thread EdwardN Onroad Nitro Engine Zone 2533 08-12-2013 10:48 AM
OS TR engine thread compaq888 Onroad Nitro Engine Zone 612 03-25-2006 04:55 AM
REX engine thread? factory racer Onroad Nitro Engine Zone 1 06-05-2005 09:42 AM
SH Engine thread ziggy12345 Onroad Nitro Engine Zone 12 02-14-2005 12:48 AM
