RB Engine Thread
#513
#514
Hi all,
I have a RB Classico 10 just bought new and am wondering where I can find replacement parts for this engine or what nova parts would work (sleeve, piston, rod etc)? Also, I read the R7 rod will work with a little modification so can anyone tell me what needs to be modded?
#515
The rod of the Novarossi Adam Drake offroad engine is the same rod and easy to find. Indeed with a reamer you could enlarge the 5mm hole of a R7 rod to fit the RB crankpin.
#517
Anyone know which novarossi piston and sleeve set is interchangeable with a Rody C6 .21?
WTB: This set if anyone has it 01146-73 Rb Piston/sleeve/rod 1006-c
#518
Try Uriah Murnan
He modified quite a few RB's and may still have parts
#519
#520
hello
I want to go back to the same configuration that I had in 2006.
namely Serpent 960/RB C5.
I found a seller for the chassis.
As for the engine, I've kept mine for all these years, but since it was a very long time ago, I don't remember if it was still in good working order.
so I want to redo the liner/piston/connecting rod.
I am offered these parts but for a C6.
I do not know this engine because after my C5 and the year 2006, I stopped everything in R/C.
was a C6 a good engine?
because I remember that my C5 had nothing to envy to the best engines of the time.
how about installing these C6 parts in my C5?
I specify that it is a "stock" version and not a "rody" prepared version.
THANKS
sorry for this "google translate" from french,if it's not sound fine
THANKS
