Old 12-03-2014, 08:22 AM   #481
Roelof's Avatar
Send a message via ICQ to Roelof
All of it. It is listed in my list:
http://www.euronet.nl/users/tooms/timings/timings.jpg
The port height is different compared with most engines because it is an extra long stroke but if you only look at the timings and compare them with many others in the list then you will see they are not special.
The quality of an answer comes with the quality of the question.
Roelof is online now   Reply With Quote
Old 12-03-2014, 03:49 PM   #482
Oso787's Avatar
[\quote]The port height is different compared with most engines because it is an extra long stroke but if you only look at the timings and compare them with many others in the list then you will see they are not special.[/QUOTE]
Thanks for the info Roelof. Nice database you got going there!
Oso787 is offline   Reply With Quote
Old 12-04-2014, 08:45 AM   #483
Roelof's Avatar
Oh wel, I did start with something and every engine I get to work on I will take the timings. It is always nice to know what is going on and you can learn a lot of them what makes it more easy to modyfy an engine.
If you have 2 same engines but performing different or feel different then you can be sure there is something different in timings. I have seen a lot of differences between same models.
I started this when I did see this list:
http://www.first-racing.eu/steuerzeiten.html
(mainly offroad)
The idea is simple with a stand that puts in some light into the crankase:
With a short manual:
http://www.euronet.nl/users/tooms/timings/manual.htm
Old 12-04-2014, 05:26 PM   #484
Oso787's Avatar
I have seen that from some research I have done. Very nice contraptions you come up with. I am trying to learn more about the function of these little engines so I can apply it to RC drag racing. Its been an interesting year or so and I have learned a lot from reading on this forum and other sources! I am making some progress in tuning but haven't got to technical yet into modifying. I have modified a few here and there but mainly opening a little the crankshaft intake. Interestingly, my best results were obtained with a stock engine and I have tried engines from a few different modifiers. I still have a lot to learn!
Old 12-09-2014, 12:20 PM   #485
Scott B's Avatar
Trader Rating: 43 (100%+)
I'm thinking of picking up an RB txr motor for my sedan. My question is do I need to use RB glow plugs or can I use nova plugs?? And will nova pipes and manifolds work well with the motor??
Thanks,
Mugen Racing USA, Sweep Racing Tires, R1 Wurks, Protoform, Speedworld Raceway...
"On-road is racing.. off-road is 50% competitive jumping and 50% crash avoidance"...
Scott B is offline   Reply With Quote
Old 12-09-2014, 09:50 PM   #486
CurveTracer's Avatar
Thanks,
I have one of the short stroke (2012) versions of this engine.
The RB 2668 pipe & manifold work best with this engine. I have found the RB glow plugs last longer, but the Nova Rossi glow plugs will work.
"Yellow Jacket" Mugen MTX-6, Picco Torque
TeamNITRO RC Club, Lynwood, Illinois
CurveTracer is offline   Reply With Quote
Old 12-10-2014, 01:26 PM   #487
Scott B's Avatar
Great thanks..
Old 03-01-2015, 01:14 AM   #488
nyamuk's Avatar
Hi nee some opinion have anyone compared beetwen this 2 engine rb txr and nova flash pt which is better interm of speed long track and reliability. Is it true rb can handle high temp due to better piston sleve compare to nova?
nyamuk is offline   Reply With Quote
Old 03-01-2015, 02:38 AM   #489
JamesHealey's Avatar
They're made in the same factory under the exact same processes, the timings of these engines are virtually identical, Novarossi piston & sleeves won't fit RB engines without a little modification. But they're essentially the same, so keeping an RB engine running beyond it's production life cycle is entirely possible using Novarossi parts, a Novarossi rod can be modified to fit an RB too if for any reason you struggle to get an RB rod.
Serpent 977 Evo | Novarossi Engines | Racing Experience Fuel | Xpert-RC Servos | Xtreme Tyres | Bitty Design Body Shells |
http://answer-rc.com/en/ - Answer RC supported driver.
JamesHealey is offline   Reply With Quote
Old 05-27-2015, 08:35 AM   #490
choisan's Avatar
is rb out-of-business? saw the news from rcspecial
choisan is offline   Reply With Quote
Old 05-27-2015, 12:30 PM   #491
Yeah RB is now closed, we got confirmation from the UK distributor recently.
Very sad news indeed.
Old 05-27-2015, 04:27 PM   #492
choisan's Avatar
Sad to hear that. The supplies of Conrod will be stopped.
I don't know of nova rossi will still produce and sell it
Old 05-28-2015, 12:07 AM   #493
Roelof's Avatar
Do not count on it.... but a R7 rod can simply be modified to fit RB.
On the other hand I think you will find the original rods for a while.
I also did read there is a possibillity that Rody will give a try to save the brandname.
Old 05-28-2015, 05:01 AM   #494
MikaR's Avatar
Very sad. I used to run RB motors in offroad. They were the best that day.
http://modelcartuning.simplesite.com/
MikaR is offline   Reply With Quote
Old 07-21-2015, 07:32 AM   #495
Trader Rating: 48 (93%+)
im looking for a SG Shaft for a V12 can you say good luck.
tcb22185 is offline   Reply With Quote
GRP... Engine... Thread... xlgraphicspro Offroad Nitro Engine Forum 2135 09-10-2013 08:46 AM
Palmaris engine thread EdwardN Onroad Nitro Engine Zone 2533 08-12-2013 10:48 AM
OS TR engine thread compaq888 Onroad Nitro Engine Zone 612 03-25-2006 04:55 AM
REX engine thread? factory racer Onroad Nitro Engine Zone 1 06-05-2005 09:42 AM
SH Engine thread ziggy12345 Onroad Nitro Engine Zone 12 02-14-2005 12:48 AM
