Old 01-16-2013, 10:07 AM   #421
pressure's Avatar
Originally Posted by desotoracing View Post
Nova C8TGH or C9TGH
Thanks desotoracing!
ITS COMPLICATED......................
pressure is offline   Reply With Quote
Old 03-04-2013, 01:38 PM   #422
Default exhaust pipe and header
Does anyone know another choice for exhaust pipe and header for rb t9 Murnan modified seems that most hobby shop are out of the 2668 rb exhaust .I was told that the reds exhaust pipe and header would work 2669. Please can I get some feedback thanks.
bigtee is offline   Reply With Quote
Old 03-04-2013, 02:24 PM   #423
Grinder's Avatar
The novarossi 2660 with 41016 header works very well.
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 03-04-2013, 03:14 PM   #424
NikoRacing's Avatar
Hipex 2669evo2 or reds 2669. For the manifold go for a C+ if you have a normal track or buy a M+ if you race on short tracks.
NICOLA PEZZOTTI - italian F1 cat. driver - Serpent 747 - HIPEX exhaust system - HOTRACE tyres - SANWA M11X
NikoRacing is offline   Reply With Quote
Old 04-13-2013, 07:31 PM   #425
1evo RRR Driver's Avatar
Send a message via AIM to 1evo RRR Driver
Fellas quick question, for you motor gurus, Can I run 20% thru my RB T11 rc in stock form? Or do i have to add a shim to the head? im in the bay Area 70-100 degrees....If I do run 20% what are signs that would say add a shim!!
"He's CHEATIN! cause Im CHEATIN! and He beat ME!" :) "D815 PILOT" /FUSION X3LCFM / M2c / ko propo RSX / M11x / Novarossi
1evo RRR Driver is offline   Reply With Quote
Old 04-22-2013, 01:22 PM   #426
I guess that question was to hard!
Here's another, is it possible to add a shim to the head to gain runtime?
Old 04-22-2013, 04:17 PM   #427
TeamCarnage's Avatar
Trader Rating: 22 (100%+)
I run the same engine. Byrons 20% 12% oil. It runs great. Never any detonation. I would add more fuel line or a Kyosho fuel filter to increase run time...
Nick Altieri
TeamNitro RC Club, New Home track- Ho Chunk Southland Expo, Lynwood IL
Serpent 748 Natrix WC, PICCO EMX "R", Spektrum DX4RPro, Futaba servos
977 EVO2, Matrix tires, Picco power.
Please drive responsibly
TeamCarnage is offline   Reply With Quote
Old 04-23-2013, 04:00 AM   #428
it will help a bit with run time and rpm,but will reduce some torque,i use the clutch setting to gain back the torque.
kyosho malaysia is offline   Reply With Quote
Old 04-23-2013, 05:21 AM   #429
Grinder's Avatar
Add .10mm of shims. This will allow you to get the most out of the engine on 20%.
You dont have to add the shim, but it will allow you to lean the engine more. It is also easier on glowplugs to add the shim.
Old 04-25-2013, 11:03 PM   #430
hay guys just wonting to know is the tXr really worth the extra $100 or is the TX good enough as iam looking to buy 2 engines at once. i see amain have them in the combo but to buy the txr in the combo it means the pipe is like $80 more.
so realy i would like to know if i would regret buying the tx cause the txr is that much better? i currently run a nova keep on so wich ever is the closest to that
Brought to you by the number 4 and the letter X
Running a Kyo MP9 TKI3 and An STRR EVO truck
rcmad2700 is offline   Reply With Quote
Old 04-26-2013, 11:38 AM   #431
Txr is a much better engine than the tx one ...it is worth the money difference
Mtx6,Reds WCS,Protoform,kopropo,contact tires.
tonyhalandri is offline   Reply With Quote
Old 04-28-2013, 01:14 PM   #432
Thank you all for the info, will add the .10
Old 11-06-2013, 05:27 PM   #433
Trader Rating: 19 (100%+)
Anyone know where I could get a piston and sleeve for a v12 rody? I believe the part number is 1700-0036r?
Cspencer225 is offline   Reply With Quote
Old 11-06-2013, 05:31 PM   #434
mkorn's Avatar
I searched the part# you posted and nothing came up. Do you have a different # by any chance?
Marty Korn
USA Team Manager
A Main Hobbies
ProTek R/C
SWORKz USA
mkorn is offline   Reply With Quote
Old 11-06-2013, 05:33 PM   #435
I got that off rb manuals they have online. I don't really know the exact motor I have as I got it used. Is there any way to tell? There is a number I graves on the side of the motor mount
GRP... Engine... Thread... xlgraphicspro Offroad Nitro Engine Forum 2135 09-10-2013 08:46 AM
Palmaris engine thread EdwardN Onroad Nitro Engine Zone 2533 08-12-2013 10:48 AM
OS TR engine thread compaq888 Onroad Nitro Engine Zone 612 03-25-2006 04:55 AM
REX engine thread? factory racer Onroad Nitro Engine Zone 1 06-05-2005 09:42 AM
SH Engine thread ziggy12345 Onroad Nitro Engine Zone 12 02-14-2005 12:48 AM
