Old 01-29-2007, 02:36 PM   #301
captian's Avatar
Originally Posted by HarKonnenD
I was inquiring about the Xenon and R version, but was steered towards the C6. Is the C6 overall a better motor? I want something powerful enough stock to be useful at 301 raceway's track. Floyd isn't a concern though as everything else I competed against with my Top had a bit more bottom and top end. I was thinking of the Ninja also, but for the price would the Xenon be better?
well this is the thing the xenon is siro based and the c6 is novarossi based .but i have two other people run at 301 with the c6 and they where happy with the engine so i would say c6 and it easy to tune
serpent america * max power * beast mods *kopropo usa* protoform * team cmdi
captian is offline   Reply With Quote
Old 01-29-2007, 02:37 PM   #302
captian's Avatar
and just to let you know floyed site is up and running again
http://www.phpbbserver.com/fanaticre...anaticremotera
Old 01-29-2007, 03:19 PM   #303
macnkitty2002's Avatar
well from what i read it sounds like its time to change the front bearing and the back plate seal. but if you do that change the seal at the base of the carb too and the should fix the problem you are having .
thanks man, will do. what brand bearing do you recommend i replace it with? the stock one, or an aftermarket one?
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 01-30-2007, 07:28 AM   #304
does an RB V15 really fit an Mugen mtx3? i always thought 2.5cc doesn't fit a 1/10th touring car..
But i had an RB V12 Rody efra legal (3ports) that thing goes like fire. it's damn fast en has lots of torque. on the straight i had short gearing and people had trouble keeping up on the straight. I ran that engine for 2 seasons and it's very reliable. I'm gonna get me another one. And damn are those engines cheap over there because this engine(RB V12 Rody efra legal) I had cotst 350 over here in holland i think thats about 450dollars or something
rocking_rabbit3 is offline   Reply With Quote
Old 01-30-2007, 08:00 AM   #305
RCRjuanabbe's Avatar
But i had an RB V12 Rody efra legal (3ports) that thing goes like fire. it's damn fast en has lots of torque. on the straight i had short gearing and people had trouble keeping up on the straight. I ran that engine for 2 seasons and it's very reliable. I'm gonna get me another one. And damn are those engines cheap over there because this engine(RB V12 Rody efra legal) I had cotst 350€ over here in holland i think thats about 450dollars or something
V15 will fit on your MTX3. Notice my signature below. I use it too for outlaw races.. enjoy!!
RCRjuanabbe is offline   Reply With Quote
Old 01-30-2007, 08:54 PM   #306
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
The V15 fits because it's a small block. Nowadays most small block .15s will fit in the same spot as a .12 motor. If it was the X15 then no it will not fit.
Captain- I know the site is up. I was talking with Rick before I gave him the idea of running the website by himself as I was going to do it. However since I don't get to the net until after 7:50pm or so, it was better he do it. I'm Bert L on there. It's def between a C6, Ninja or the 35 Plus.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 02-02-2007, 05:09 PM   #307
captian's Avatar
ok cool just trying to get the word out .
there all good so good luck
Old 02-02-2007, 09:12 PM   #308
RC FORUM has updated great pictures of RB new products from Toy Fair.
http://rcforum.co.kr/
We are currently adding more pictures now untill Toy Fair finishes.
WORLD BEST RC NEWS
RC FORUM
HTTP://RCFORUM.CO.KR
Send us your RC news to us info@rcforum.co.kr
rcforum is offline   Reply With Quote
Old 02-07-2007, 09:33 PM   #309
bsmooth's Avatar
Trader Rating: 17 (100%+)
Default Tuning
Question about tuning my C6 (or any other engine):
I always thought by turning the LSN clockwise, I am leaning it out. Therefore, if the engine takes a while to come down to idle it is too lean (not loading up fast enough with fuel). Somebody (Rich B.) confirm or correct me on this.
Also, how long should the engine be able to idle before loading up?
Thanks,
Steve
bsmooth is offline   Reply With Quote
Old 02-08-2007, 05:53 AM   #310
Thanks,
Steve
You have to be sure your idle is set, first. Many times when a car comes in to the pits with a "hot" idle - the idle/low end needle balance is off. The tuner will head for the needle on the bottom - the problem is the idle setting. Be sure to confirm your system has no leaks (pressure system or exhaust system) - none!
I like to tune with a very low idle - (with the motor close to temp) I rap the throttle... the motor should fall right to a perfect idle no climb no fall off. With a low idle, if the idle increases (right after the rap) it is lean on the bottom - fatten slightly. If the idle decreases or stalls it is too fat. That requires some practice - but, it is the key to tuning. I can bench tune the bottom and focus on the mid and top end on the track. On rare occasions we may work the bottom tune to gain some punch out of the corners. Best you don't try this trick.
I can tune the car to idle smoothly for 5 minutes or 10 seconds. The tighter the compititon the shorter the idle window. Every track has a slightly different tune requirement.
Rich Browne is offline   Reply With Quote
Old 02-08-2007, 05:28 PM   #311
bsmooth's Avatar
Thanks Rich.
Could you also give me some tips on how you break in the engine using a run in bench? Any differences I should be aware of compared to running it in on the track?
Regards,
Steve
Old 02-08-2007, 05:59 PM   #312
Thanks Rich.
Regards,
Steve
Everyone has an opinion on "motor break-in".
Here's what I do. Motor in car or bench. Not on track. First and foremost - use a heat gun to warm the motor to 200 F. Start the motor, run at a high idle very fat (almost 4 cycling) spitting oil out of the pipe - temp won't get over 140 - run 85 CC's. Then without stopping the motor bring the temp to 165 - 180 F run 4 tanks. I pull the sleeve at 4 tanks and look at the "pinch band" on the sleeve. If the wear is very even around the sleeve (360) you'll have a dandy motor. If the wear is uneven - well that won't be the worlds best motor. Go ahead to the track - take it easy until you have about a liter through the motor - then take it to temp.
Remember preheat your motors - it will save you in piston and sleeve life - read $'s!
Old 02-09-2007, 06:36 AM   #313
bsmooth's Avatar
Thanks again Rich.
Old 02-19-2007, 05:36 PM   #314
Good tips Rich!!!!
Hey Rich,
Your personal opinion.... be truthful.
How is C6 Rody compare to C5 Rody. I am in the market for an engine.
Old 02-19-2007, 06:07 PM   #315
Originally Posted by RCRjuanabbe
Good tips Rich!!!!
Hey Rich,
The C6 is an improvement over the C5. The C5 was a solid motor - the C6 is a fast/solid motor. Scott has been running C6's since March of last year. Very impressive. Play with Header and Pipe combos - loads of hidden power. Try RB's 2013 pipe with the matching conical manifold - I wrenched for Rody (and Scotty, too) in Vegas last October, Rody's comment on our set-up: "That is just brutal power". Too bad Rody's battery pack broke in the main.
The Xenon R's are faster - but, sensitive to tune. The C6's are powerful - and very easy to tune - just a "tick" slower.
GRP... Engine... Thread... xlgraphicspro Offroad Nitro Engine Forum 2135 09-10-2013 08:46 AM
Palmaris engine thread EdwardN Onroad Nitro Engine Zone 2533 08-12-2013 10:48 AM
OS TR engine thread compaq888 Onroad Nitro Engine Zone 612 03-25-2006 04:55 AM
REX engine thread? factory racer Onroad Nitro Engine Zone 1 06-05-2005 09:42 AM
SH Engine thread ziggy12345 Onroad Nitro Engine Zone 12 02-14-2005 12:48 AM
