Old 03-15-2014, 12:52 AM   #1
Default OS speed R2101
Hi guys,
I have a question regarding the above mentioned engine.
I got this engine from a friend of mine. He bought it last year in Japan during the World's.
It should be an engine which was made for the japanese teamdrivers.
See also art. picture...
Can someone tel me if it is a special modified or same then the standard one?
HARM SX4; modified Zenoah 23ccm DW XR23; 4x Futaba S-9353
Serpent 977; Novarossi 35plus WC
Futaba 4PX
Shanghai S51 club
supacha is offline   Reply With Quote
Old 03-15-2014, 06:51 AM   #2
Arahawak's Avatar
Trader Rating: 32 (100%+)
Originally Posted by supacha View Post
Hi guys,
The OS 2101 was quite readily available during the Worlds in Japan last year.
Unless your friend got it from the team driver, maybe it is special.
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 03-15-2014, 07:38 AM   #3
No he got it from a Futaba shop. But they told him it was the pre engine for the teamdrivers.
I know that for example Novarossi mark them with a red dot on the rear side screw.
Can't see anything on my engine.
I am just asking because I am interested.
I will see after breaking in :-)
Futaba 4PX
Shanghai S51 club
Old 03-15-2014, 11:11 AM   #4
Arahawak's Avatar
It's a standard..
I don't know if the team drivers like Hara and Shimo are running 'team' R2101s but the only special OS R2101 I saw was the Maxima R2101 on Gilles' and maybe a few more other drivers.
Old 03-15-2014, 12:45 PM   #5
Suspended
Send a message via ICQ to Roelof
Isn't it just a replica?
Mostly manufacturers do produce a WC replica engine because people ask for it.
Roelof is offline   Reply With Quote
Old 03-16-2014, 01:12 AM   #6
Arahawak's Avatar
The Maxima version? A fair bit of work was put into it from what I saw
Old 03-17-2014, 02:29 PM   #7
Hi ,
On the engine if you see letters WC2013 and the number for the engine then it was for team driver .
Regards
Skem61 is offline   Reply With Quote
Old 03-18-2014, 06:51 AM   #8
Ok. It is a normal engine then.
There is no number on the crankcase, only the letters RH on the mounting flange.
How is your experience between the OS and the Novarossi 35 plus QC?
Which one is for technical narrow tracks better?
Futaba 4PX
Shanghai S51 club
Old 03-18-2014, 09:22 AM   #9
OS provide better torque than 35 plus
kyosho malaysia is offline   Reply With Quote
Old 04-21-2014, 12:27 PM   #10
JamesHealey's Avatar
Those who have tried them here in the UK have said they have a lot of torque and need gearing higher than other motors, the fact it produces it's peak power 8000rpm lower than a Novarossi probably has something to do with this.
We have a few drivers in the UK running them, be interesting to see how they go!
Serpent 977 Evo | Novarossi Engines | Racing Experience Fuel | Xpert-RC Servos | Xtreme Tyres | Bitty Design Body Shells |
http://answer-rc.com/en/ - Answer RC supported driver.
JamesHealey is offline   Reply With Quote
Old 08-13-2014, 04:49 AM   #11
choisan's Avatar
In Japan, it has a limited edition of 200 sets. With matched piston set,....with pipe.
choisan is offline   Reply With Quote
Old 08-31-2014, 08:33 AM   #12
Angry main bearing failure
Hi guys,
Here a quick feedback and hopefully replys on how to do now...
After breaking in the engine with the heatcycle method (about three liter) I joined this weekend our club race.
After finetuning the engine went really well, couldn't even use the power on many parts of the track..
Highest measured temp was 116℃. Adjusted to 100 to 105℃ afterwards.
Ambient temperature was 27℃.
After the first main the engine lost dramatically on power and died several times...
Tod I disassembled everything and found this:
Piston/sleeve have several fine scratches (mainly on the intake side)
Main bearing has about 0.1 to 0.2mm radial gap and about 0.1 mm axial gap - it sounds now like a music instrument
Conrod has on the rearside also scratches
The crankcase has deeper scratches on the bottom side - comes from the crankshaft
I guess it is a bearing failure. The crankshaft created metal shavings from the crankcase and they came to the piston/sleeve.
Do you guys think it is useful to contact OS for this?
PS: airfilter was brand new and temperature gun was an exergen...
Futaba 4PX
Shanghai S51 club
Old 08-31-2014, 08:54 AM   #13
Default Picture
here is a picture of the crankcase.
You can see the touching area which comes from the crankshaft on the bottom right next to the groove for the conrod.
I can press the crankshaft easily by hand against the crankcase - with mounted bearings....
Futaba 4PX
Shanghai S51 club
Old 08-31-2014, 08:59 AM   #14
Futaba 4PX
Shanghai S51 club
Old 08-31-2014, 11:15 AM   #15
Trader Rating: 23 (100%+)
It wouldn't hurt to send the report into OS and see what they say. What fuel were you running as it look like there is some corrosion on the bearing outer race??
Serpent Viper 977e, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.0, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
