Capricorn XRD-F Engine
#62
Just a fyi.
I used to stop my offroad engies by plugging the exhaust. I used alot of glowplugs. I have now stopped doing it, stopping my engines on the flywheel insted. My glowplugs now last alot longer :-)
#63
With the testing we have done, you need to add a .1 shim to run 25%. It gives good power but can be sensitive to tune. Your temps will be lower than you are used to also. If you add .15, it will be safer and easier to tune and temps will be about the same as when you ran your 16%.
DJ Apolaro
DJ Apolaro
I've found out the 2 x 0.1mm and the under sleeve shim, the total head clearance around 0.58~0.62, there is lack of low end power.
#64
I have found that if you are running a good fuel, you can run .5 total clearance. Leave the shim under the sleeve and play with the shims under the button till you get the total clearance of .5
This will help with the low end torque.
DJ Apolaro
#65
Thanks! That's what I though about
#66
but will lost some top end
#67
That is correct. But I can say with these motors, they have good top end and you will not notice much of a difference when you change the shim on the top. Unless you run on a very large track.
DJ Apolaro
DJ Apolaro
#68
When I take away the shim under sleeve, and add 0.1 head shim to maintain the head clearance in 0.5. The overall power is back!!!! About 110C. But the punchy low end power is lower then with the under sleeve shim.
So, I know the under shim makes the port higher, but what does the higher port mean?
I wish to put the under.shim back to retrieve more low end power, but I don't know how to tune it to get back the mid and top end power. Any clue ?thx
#70
Interesting thing was found. I did the soldiering test the head clearance is about 0.53, good figure . But the engine is lack of power, only the punchy feeling i can feel when exit.the corner, then no power at all. It was about 120C.
#71
Well, if the under shim acts as raising the charge and discharge actions, I understand the fuel consumption will be higher. So, if the charging action faster, does it mean the needles need a bit richer to feed enough fuel?
#72
Of course you know that when you place the undershim you will get a higher exhaust port, which will yield more rpm’s, so more top end, and inversely lower exhaust will yield less rpm’s, so more low end, but take into account that with the undershim you also move the transfer ports timing higher.
First of all we know that difference between transfer and exhaust duration needs to be at least 40 degrees so the tuned pipe works properly, then second thing you have to take to consideration is fuel consumption, higher transfer = more fuel will go, and some of it will not burn, then fuel consumption will go down.
In my opinion from what I’ve learned on RC cars motors is that .12 size transfer needs to be around 116-122 degrees. Everything over is going to hurt run time, everything lower will work against performance.
Just remember whatever you do, keep difference between transfer and exhaust 40 degrees at least.
Induction (crank opening) timing works like this: earlier opening = more low end . Later closing = more top end.
Also keep in mind that the greatest boost in power is gained by increasing total induction duration, and increasing inner diameter of passage in crankshaft.
With respect to head clearance:
Small chamber = Advanced ignition = Colder plug = More torque
Bigger chamber = Retarded ignition = Hotter plug = More top end
Plugs alone, with same chamber will give you: Hot plug = more top end. Cold Plug = more low end
So there is no special formula, it’s just more up to trials. You see on our RC cars application specially on .12 motors we need some torque, some RPM, and fuel mileage.
Hope this helps
AFM
#73
usually i leaner LSN,richer the HSN compare to standard engine setting but i do mofidied the piston,crankshaft timing,crankcase,sleeve and button.
#75
