Help ME
Help ME
I got a problem my engine after some time of high speed run it seems to be smoking whats wrong???
you may have ran it to lean and damaged it.
hmm but i open the low end and high end by 5 turns so should it be rich
Yes you want smoke out of the pipe while its running Full throttle. This means you have a good amount of fuel going through the car and its getting good lubrication.
If its smoking after its off that could be something else. Do you have a temperature gauge. If not you might want to get one of those so you can more easily see if the car is running hot or cool.
