nitro % hotter or colder
I used to be under the impression that the less the nitro percentage the cooler the engine would run.. after seeing several threads of people stating both I'm not so sure anymore.., so I would like to hear which one it really is... and if you can please explain why...
thanks. |
the higher the content the cooler it will run . but make sure you adjust your plug heat range to match ..
OS Engines claims "in colder climates to increase the nitro content".
Originally posted by 3434 OS Engines claims "in colder climates to increase the nitro content". |
