Old 05-21-2014, 10:33 AM   #121
Flyin Hawaiian1's Avatar
Originally Posted by Grinder View Post
Modifications are allowed. As long as the engine still conforms to the rules.
For those of you that want to keep up with the Factory guys...........You need to talk to Uriah Murnan.......That's all I can say....
Andy Liu "Flyin' Hawaiian"
Flyin Hawaiian1 is offline   Reply With Quote
Old 05-21-2014, 10:40 AM   #122
Pit-racer's Avatar
Thumbs up
Coming to get you lil' andy.
www.igthobbies.com / Serpent Eryx 3.0 / Desoto Racing / Veytrex.com / JZRacing / RcShox / IGT8 Red
Pit-racer is offline   Reply With Quote
Old 05-21-2014, 11:04 AM   #123
FastPete's Avatar
Trader Rating: 44 (100%+)
Oh WOW really?
Authorized Dealer for /Agama / Tekno / Team Associated / Schelle / Hobbywing / PT Racing Shock & Diff oil / Serpent / Tekin / JConcepts / AKA / Proline / Savox / M2C / Picco / www.fiercercsolutions.com Like us on facebook www.facebook.com/FierceRCSolutions
FastPete is offline   Reply With Quote
Old 05-21-2014, 04:28 PM   #124
Default fact
That's a fact jack
Jimmy W is offline   Reply With Quote
Old 05-21-2014, 06:22 PM   #125
Pit-racer's Avatar
Talking
So you're saying the factory guys all run mm's? Or to try to catch them with what they're using you need a mm's? That's all I'm asking.....someone once told me it's all in the set-up.
Old 08-23-2014, 07:16 AM   #126
any comments if i were to install with a Reds Racing M7 WCS?
xscape is offline   Reply With Quote
Old 08-23-2014, 07:20 AM   #127
Grenade10's Avatar
Trader Rating: 37 (100%+)
I've seen racers run the M7 in the GT, but they were looking for a larger heat sink, as the airflow in the GT body is not nearly as good as an 1/8 open.. Reds engine needs to run cooler that a novarossi.
I have a 5R that I will have available for ROAR rule events, so 5 ports and 7mm restrictor.
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 08-29-2014, 01:36 PM   #128
Pit-racer's Avatar
So to comply with ROAR rules on an engine it has to be a bone stock not tuned version 5port? Or any modifications with a 6mm venturi?
Old 08-29-2014, 03:34 PM   #129
Up to ANY .21 5 port engines with 7mm venturi or smaller.
Old 08-30-2014, 03:27 AM   #130
Roelof's Avatar
Send a message via ICQ to Roelof
Crazy rule.....
So you can buy a stock 5 port engine, let it modify for high costs, put in some expensive ceramic bearings while for the same price you can get a Virtus......
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 09-23-2014, 12:40 AM   #131
Joseph16's Avatar
Crazy rule.....
Theres no need for ceramic bearings to run Gt!
Serpent America & Desoto Racing.
Picco - Arrowmax.
PT RC Racing Oils.
Neal Smith Mods.
Alpha Tires and Body.
Joseph16 is offline   Reply With Quote
Old 09-23-2014, 06:34 AM   #132
Joe Kimble's Avatar
Send a message via Skype™ to Joe Kimble
Crazy rule.....
I agree with you it's not a great rule... Jose is right we don't need ceramics in a GT but we do run modified engines for sure. And they are crazy fast engines weather it's Murnan or Clockworks.
Some GT racers run non modified high end 5 port engines such as the RB BXR DI5 which is a monster powerhouse or screamers like the REDS 5 port but they still are disadvantaged compared to guys who can use the potential of a modified engine.
In my opinion this rule does not even-up the field, because it requires more knowledge to run a modified (or very fast) 5 port engine efficiently and not everyone has that knowledge nor is willing to incur the cost of sending their engine out.
At the end of the day it's great to have strict rules for everyone to comply with, but I'm not a fan of this one because it doesn't serve the purpose is was created for. For one it doesn't keep us from running ballistic engines and also there is still a big variety of engines on the track. In my opinion, the IGT8F spec rules had some great ideas but the GT8 field is not big enough right now to separate "open" and "spec"...
Just my 2 cents
Serpent America
Sweep USA
RCShox
Joe Kimble is offline   Reply With Quote
Old 09-23-2014, 10:57 AM   #133
Roelof's Avatar
Sure you do not have to run ceramics as this counts for more than 90% of the drivers in any competition. But look on these forums, even a starter asking which engine to buy shall be informed to get a Murnan. Also a lot of drivers "feel" they do need ceramics as also the same group of drivers still think 9 poorts are needed to go faster than a 5 port not knowing the the real reason what makes an engine fast.
Such rules are normally to lower the costs and make the performance more equal. A nice but bad thought if a modify to the extreeme is alowed....
Old 09-23-2014, 11:32 AM   #134
Joe Kimble's Avatar
Agreed. Yes telling a starter to get a modified engine will only help him get frustrated I'm sure since he/she will either blow it or put the car straight into the boards.
To be honest I'm still doing a lot of reading about what makes an engine fast. From what I read/heard there are many things such as timing and balancing on the crankshaft, position of the sleeve and height of the ports and exhaust ports, size of the ports and of course pipe and header choice.
Still not exactly sure what exactly does what. Only thing I really noticed is that with the silicone ramp in crankshaft the engine spools up faster and is more reactive. And even then the timing had probably been altered on top of adding a silicone ramp so not sure of the exact contribution of the silicone ramp compared to timing...
Is true that a modified 5 port is just as fast if not faster than any 9 port I have (I tested this only in GT, for 8th scale I don't know).
About your last point, I agree. This is exactly why this rule is useless. At the end of the day it's really difficult to control the engines, unless they are sealed and hand out at the event. lol
Serpent America
Sweep USA
RCShox
Old 09-23-2014, 02:36 PM   #135
Wink
Agreed. The silicone helps but the power generally comes from the alignment of crank timing to sleeve/piston matching...
V-one-RR Evo,V-one-RRR (WC hopped-up),2007 Evolva,
Spada 09,MR-02,MR-03
Inferno GT2. Serpent Cobra GT
KF01 - F1, Serpent Viper 977WC, Serpent Natrix 748
1FastVW is offline   Reply With Quote
European 2wd 1/8th pan car on-road Classic class djmachinist Nitro On-Road 4194 03-26-2017 06:30 PM
GT8 Class--buggy-based on road electric! snrscion Electric On-Road 3418 02-02-2017 05:39 AM
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
Nitro On-Road Addict sa RC Manila Racers 12522 12-27-2015 05:51 PM
