Old 11-02-2014, 09:16 PM   #181
JLock's Avatar
Originally Posted by Bundy_Bear View Post
In my opinion this won't make any difference and doesn't address the issues of engine reliabilty and reducing overall costs for those that run this class on a regular basis. Out of the regular top four drivers in the class only one is running the latest generation chassis and if he was made to go back to an older car the end result will still be the same.
The engine issue is not that hard to fix. Of the lesser expense .12 engines currently on the market, find one that is more reliable than the OS 12TG, find a pipe that is a good match to it, and move on from there. The one engine/pipe makes it easier to tech against illegal modifications which would disqualify a racer from the spec class. As far as the possible chassis rule, it helps to make the class more affordable because you are not spending the high dollars needed for the "latest/greatest". It also affords someone that may have an older model car to dust it off, just update the engine and pipe, and have another participant that you might not have had if that person was shelling out major coin and the latest fill-in-the-blank. Just some food for thought.
Texas 5
It's not what you know; it's what you can prove.
The only thing that is for sure is that nothing is for sure!!!
The needs of the many outweigh the needs of the few, or the one.
There are 2 things in life that are infinite: the universe and stupidity.
JLock is offline   Reply With Quote
Old 01-24-2015, 08:15 PM   #182
Originally Posted by Bishop View Post
Australia has been getting into 8th GT on what looks to be the tail end of the 'bubble' for it, I'm not convinced the rules for it are even remotely what they should be for the intent of the class.
What were the rules over there originally?, now I'm seeing two speeds, up to 8 ports, 9mm inserts all being ok, I don't see how now them being cheaper to run than an 8th elite wing car, the tyres for the GT don't look cheap either.
I liked how the 8th GT looked like 2-3 years back, now it looks like you'd spend way more than 200mm, and running costs like real 8th scale.
Hi Bishop,
I wrote the draft GT rules and AARCMCC have sanctioned the class for the 2015 NSW titles, call me and we can discuss...
Rob
Hi all come and join us,
We have completed the information for the AARCMCC NSW Titles, go to our web site for the entry form and to register -- http://www.nswrcrcc.com/#!news/c1x9v
John Grant Raceway, dates: 2nd, 3rd, 4th and 5th of April 2015 (Easter weekend)
A new thread for the 2015 NSW Titles has been created
2015 AARCMCC I.C. NSW STATE CHAMPIONSHIPS
File Type: pdf AARCMCC IC ONR GT Technical Rules 201405 DRAFT C.pdf (77.6 KB, 47 views)
rptech1 is offline   Reply With Quote
European 2wd 1/8th pan car on-road Classic class djmachinist Nitro On-Road 4194 03-26-2017 06:30 PM
GT8 Class--buggy-based on road electric! snrscion Electric On-Road 3418 02-02-2017 05:39 AM
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
Nitro On-Road Addict sa RC Manila Racers 12522 12-27-2015 05:51 PM
