Old 04-12-2005, 04:38 PM   #1
Default Jp Prob
I have just started out racing cars and have a JP BLACK .12 engine. The piston locks up almost at the top of the strokedoes anyone knew what us cause this or how i can fix it?
The engine is brand new
Thanks for the help
gooey is offline   Reply With Quote
Old 04-12-2005, 05:06 PM   #2
Trader Rating: 27 (100%+)
Send a message via AIM to Scott Fisher
It is supposed to do that especially when it is new. The best thing to do is try heating the case with a hair dryer. This will loosen it up just a little.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 04-12-2005, 05:18 PM   #3
Thanks very much
Old 04-15-2005, 06:06 AM   #4
Have you broken it in?
If not, you need to break it in by 'heat cycling' it in your car at first.
Remove the glow plug then using a flywheel wrench unlock the piston from the sleeve.
Replace the plug and start the engine. Raise the idle slightly ('manually') using the throttle. 'Richen' the high end or top end needle by turning it counter clockwise one turn.
Once the tank is empty. move the piston to the BDC (bottom dead center) position. (The flywheel rocks back and forth freely)
Let it cool for a few minutes, then repeat three more times using various throttle positions.
The fifth tank is done driving around a track with you leaning out the top end 1/8th of a turn at a time after the engine is at operating temp.
This should give you a reliable long life engine.
Good luck!
NitroHead is offline   Reply With Quote
TT-01 Servo prob Ausdrifter Electric On-Road 6 12-21-2008 05:42 PM
Engine prob.... xscape Nitro On-Road 7 12-29-2006 01:32 AM
nitro prob Partyphil Rookie Zone 3 06-04-2006 04:13 PM
lst battery prob? rockn Monster Trucks 12 07-26-2005 04:58 PM
my new car setup and a prob. (i think) hongbits Rookie Zone 8 07-24-2005 02:41 PM
SEO by vBSEO 3.5.0
